Apache2 default page (not redirecting subdomains or www) after cert installed
My domain is: clearpath.site and *.clearpath.site
My web server is (include version): Apache2
The operating system my web server runs on is (include version): Ubuntu 19.10
I am receiving the Apache2 Ubuntu Default page when visiting subdomains of my website - or at least some people are reaching the default page and some are not. I am sure it has to do with the .conf file setup incorrectly but I cannot seem to figure it out. It seems that www is the site that gives this page. Shouldn’t that be caught by the wildcard Alias?
check your website
  GNU nano 4.3                                         000-default.conf
<VirtualHost *:80>
        ServerName clearpath.site
        ServerAlias *.clearpath.site
        DocumentRoot /var/www/html
RewriteEngine on
RewriteCond %{SERVER_NAME} =clearpath.site [OR]
RewriteCond %{SERVER_NAME} =*.clearpath.site
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
And me VH for port 443:
<IfModule mod_ssl.c>
<VirtualHost *:443>
        Alias /static /home/david/clearpath_project/static
        <Directory /home/david/clearpath_project/static>
                Require all granted
        </Directory>
        Alias /media /home/david/clearpath_project/media
        <Directory /home/david/clearpath_project/media>
                Require all granted
        </Directory>
        <Directory /home/david/clearpath_project/config>
                <Files wsgi.py>
                        Require all granted
                </Files>
        </Directory>
        WSGIScriptAlias / /home/david/clearpath_project/config/wsgi.py
        WSGIDaemonProcess django_app python-path=/home/david/clearpath_project python-home=/home/david/clearpath_project/>
        WSGIProcessGroup django_app
SSLCertificateFile /etc/letsencrypt/live/clearpath.site/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/clearpath.site/privkey.pem
</VirtualHost>
</IfModule>
Any help is appreciated.
I’m not a big fan of “if servername X or servername Y then DO …”
When you probably want to always DO …
So, I would first update the four rewrite lines to:
RewriteEngine On
RewriteRule ^\.well-known\/acme-challenge\/ - [L]
RewriteCond %{HTTPS} !=on
RewriteRule ^/?(.*) https://%{SERVER_NAME}/$1 [R,L]
[which basically says: when NOT a challenge request and NOT HTTPS redirect to HTTPS]
If that doesn’t fix the problem - which it probably won’t.
I would then check for name overlap with:
apachectl -S
[apache it tricky in that it will allow you to have name overlaps and never complain - unlike others]
[And it will serve from only the first match; so that may be why you don’t get your desired result]
What do you mean by “name overlap”?
Also, when I run: apachectl -S I get:
AH00526: Syntax error on line 49 of /etc/apache2/sites-enabled/000-default-le-ssl.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/clearpath.site/fullchain.pem' does not exist or is empty
Action '-S' failed.
When multiple vhost configs contain similar names or overlapping names.
Where the webserver could match the requested name with multiple vhosts.
Can we see this line (or entire file):
And the full contents of this folder:
ls -l /etc/letsencrypt/live/clearpath.site/
<VirtualHost *:443>
                Require all granted
        </Directory>
                Require all granted
        </Directory>
                <Files wsgi.py>
                        Require all granted
                </Files>
        </Directory>
</VirtualHost>
</IfModule>
Looks like root has all rw permissions if I read this correctly:
lrwxrwxrwx 1 root root  38 Dec 18 20:43 cert.pem -> ../../archive/clearpath.site/cert1.pem
lrwxrwxrwx 1 root root  39 Dec 18 20:43 chain.pem -> ../../archive/clearpath.site/chain1.pem
lrwxrwxrwx 1 root root  43 Dec 18 20:43 fullchain.pem -> ../../archive/clearpath.site/fullchain1.pem
lrwxrwxrwx 1 root root  41 Dec 18 20:43 privkey.pem -> ../../archive/clearpath.site/privkey1.pem
-rw-r--r-- 1 root root 692 Dec 18 20:43 README
hmm…
All that looks NORMAL and expected…
Please show:
ls -l /etc/letsencrypt/archive/clearpath.site/
-rw-r--r-- 1 root root 1931 Dec 18 20:43 cert1.pem
-rw-r--r-- 1 root root 1647 Dec 18 20:43 chain1.pem
-rw-r--r-- 1 root root 3578 Dec 18 20:43 fullchain1.pem
-rw------- 1 root root 1704 Dec 18 20:43 privkey1.pem
Ok… that looks good too…
Please show this file:
/etc/letsencrypt/options-ssl-apache.conf
This is safe to show?
# this file.
SSLEngine on
# Intermediate configuration, tweak to your needs
SSLProtocol             all -SSLv2 -SSLv3
SSLCipherSuite          ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
SSLHonorCipherOrder     on
SSLCompression          off
SSLOptions +StrictRequire
# Add vhost name to log entries:
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-agent}i\"" vhost_combined
LogFormat "%v %h %l %u %t \"%r\" %>s %b" vhost_common
#CustomLog /var/log/apache2/access.log vhost_combined
#LogLevel warn
#ErrorLog /var/log/apache2/error.log
# Always ensure Cookies have "Secure" set (JAH 2012/1)
#Header edit Set-Cookie (?i)^(.*)(;\s*secure)??((\s*;)?(.*)) "$1; Secure$3$4"
Yes (very) it should be all DEFAULT - but I want to check to be sure.
The only thing you NEVER EVER show is the contents of any PRIVKEY file.
On the check your website it shows that I need a redirect but I have one?
You have a broken config; as shown by the failed apachectl -S
But I don’t see WHERE…
Please show this output:
[NOT THE FILE CONTENTS]
ls -l /etc/letsencrypt/live/clearpath.site/fullchain.pem
ls -l /etc/letsencrypt/live/clearpath.site/privkey.pem
Then check the contents - don’t post these:
cat /etc/letsencrypt/live/clearpath.site/fullchain.pem
cat /etc/letsencrypt/live/clearpath.site/privkey.pem
ENSURE THERE IS CONTENT VISIBLE
david@clearpath:/etc/letsencrypt$ sudo ls -l /etc/letsencrypt/live/clearpath.site/fullchain.pem
lrwxrwxrwx 1 root root 43 Dec 18 20:43 /etc/letsencrypt/live/clearpath.site/fullchain.pem -> ../../archive/clearpath.site/fullchain1.pem
david@clearpath:/etc/letsencrypt$ sudo ls -l /etc/letsencrypt/live/clearpath.site/privkey.pem
lrwxrwxrwx 1 root root 41 Dec 18 20:43 /etc/letsencrypt/live/clearpath.site/privkey.pem -> ../../archive/clearpath.site/privkey1.pem
And yes, the keys exist.
Please show:
apachectl -t -D DUMP_VHOSTS
and
apachectl -t -D DUMP_RUN_CFG
david@clearpath:/etc/apache2/sites-available$ sudo apachectl -t -D DUMP_VHOSTS
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 173.230.154.79. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:443                  clearpath.site (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
*:80                   clearpath.site (/etc/apache2/sites-enabled/000-default.conf:1)
So it sees both vhost configs well enough…
What about:
sudo apachectl -t -D DUMP_RUN_CFG
david@clearpath:/etc/apache2/sites-available$ sudo apachectl -t -D DUMP_RUN_CFG
ServerRoot: "/etc/apache2"
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
HUH???
Please show:
sudo apachectl -S
david@clearpath:/etc/apache2/sites-available$ sudo apachectl -S
Define: DUMP_VHOSTS
I am totally lost now XD
That makes two of us!
Try removing these two lines:
and restart web server.
[I have to step out for a few (~20) minutes - I will return - if no one else chimes in]
