Another certificate renewal (authorization) issue
Having used Let’s Encrypt for quite some time now, I’m suddenly getting authorization errors when trying to renew my certificate. I think this may be related to my adding an additional hostname, rehash.altmode.net, to my certificate (although this worked the first time, apparently.
Authorization fails because it is expecting a certificate for (for example)
c954623697823548af59563dd1c37ae9.1cf61a4662aad873049ed8fe2d763bb4.acme.invalid
and getting a certificate for
d0a523b0300eb48035b680c5132880b0.e74f2b5ce0f3595d184567d06f633244.acme.invalid
The expected certificate name is different every time I try, but the received certificate (d0a523…) is the same every time. Furthermore, this is apparently the certificate name used for the rehash.altmode.net challenge.
In reading through other cases, it sounded like there was some doubt about whether this works correctly with IPv6, and as you can see (below) I am using IPv6.
Console output below; can also provide verbose output if needed.
root@altmode:/var/log/letsencrypt# certbot renew --dry-run
Processing /etc/letsencrypt/renewal/altmode.net.conf
Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
tls-sni-01 challenge for altmode.net
tls-sni-01 challenge for rehash.altmode.net
/usr/lib/python2.7/dist-packages/OpenSSL/rand.py:58: UserWarning: implicit cast from 'char *' to a different pointer type: will be forbidden in the future (check that the types are as you expect; use an explicit ffi.cast() if they are correct)
  result_code = _lib.RAND_bytes(result_buffer, num_bytes)
Attempting to renew cert from /etc/letsencrypt/renewal/altmode.net.conf produced an unexpected error: Failed authorization procedure. altmode.net (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested e5f1b203fb9015eb8807021676e9b589.16d972a4ecbb96e8d26747b27825d05e.acme.invalid from [2607:f2f8:a994::32ca]:443. Received 1 certificate(s), first certificate had names "d0a523b0300eb48035b680c5132880b0.e74f2b5ce0f3595d184567d06f633244.acme.invalid, dummy". Skipping.
**          (The test certificates below have not been saved.)
  /etc/letsencrypt/live/altmode.net/fullchain.pem (failure)
**          (The test certificates above have not been saved.)
   Domain: altmode.net
   Type:   unauthorized
   Detail: Incorrect validation certificate for tls-sni-01 challenge.
   Requested
   dummy"
May be domain “rehash.altmode.net” 's DNS AAAA record not take affect in global or no ipv6 route to the server!
And sometimes the LE’s tls-sni challenge disabled will cause tls-sni challenge failed!
See the active incident. Probably related. https://letsencrypt.status.io/ – hopefully just temporary.
The log indicates that it got an authorization failure message from the server. So I don’t think that’s it.
Possibly, although my renewal problems started on January 7, as soon as my certificate got within 30 days of expiration, and it sounds like the incident just occurred. But thanks for the heads up; I won’t try to do any more debugging until the incident is resolved.
