Another Apache Certbot Configuration Issue
My domain is: whatsupgoose.org
I ran this command: certbot --apache
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: whatsupgoose.org
Requesting a certificate for whatsupgoose.org
Domain: whatsupgoose.org
Detail: 2606:4700:3035::6815:54d9: Invalid response from http://whatsupgoose.org/.well-known/acme-challenge/o4WbxaaQpUIcXEzCKE9FTEgxttVmRbSreopOvF9Gcvc: 522
My web server is (include version): apache
My hosting provider, if applicable, is: cloudflare
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.1.0
Welcome @upgoose
Your domain is proxied at Cloudflare. Nothing wrong with that but it does take special care to get a cert on your Origin server with a CDN in front of it.
The 522 is an HTTP error code. That means the Cloudflare CDN edge could not communicate with your Origin server. See: Error 522 · Cloudflare Support docs
That's the first thing to sort out. I couldn't repeat that error now so let us know if you are getting different results now.
The second thing I'd suggest is seeing if the Cloudflare Origin CA certificate would work for you. If so, you wouldn't need Certbot at all. Instead, you get a self-signed cert from Cloudflare which you can set with a very long expiration. It allows encrypted comms between the Cloudflare edge and your Origin.
See: Cloudflare origin CA · Cloudflare SSL/TLS docs
i am unsure how to resolve the 522 error. I can adjust whether the A record in cloudflare is proxied, but that just changes the error from 522 to "Timeout during connect (likely firewall problem)"
I'd start by unsetting the proxy for your A and AAAA records just to simplify.
Can you explain more about how your Apache server is hosted? Things like is this a residential ISP and are there any firewalls or other comms gear you are using?
I can connect to your domain with HTTP and HTTPS but not for the /.well-known/acme-challenge path
That suggests that something is interfering on your end. A firewall may be blocking that path. Or, some other device wants to handle those kinds of challenge requests itself but is failing. Or, maybe a router is sending such requests to the wrong local IP at your location.
Cloudflare just adds complications to the debug process at this stage.
The Let's Debug site is often helpful with new setups. https://letsdebug.net
Making repeated failures against the LE production system will get you temporarily blocked. That isn't the cause of your 522 or timeout problem but could happen with repeated attempts.
Or, at least use the LE staging system like this
sudo certbot certonly --dry-run --apache -d whatsupgoose.org
I am self-hosting apache using a debian-based container through proxmox. There shouldnt be any firewalls between the container, node, or the router. My ISP is residential, and i'm currently using a TP-Link router. I am not exactly sure of the IPv6 address, and may possibly just start over from container creation, ensuring to create static IP addresses for both IPv4 and IPv6 and linking them to the A and AAAA records on cloudflare.
If the router is sending to the incorrect local IP, I would check that through the router's web interface?
I think this is not likely a problem since requests to your "home" page get through as well as other requests getting a 404 Not Found. Your router would have to be handling the .well-known path uniquely.
From your local network does this work?
curl -i http://(localIP)/.well-known/acme-challenge/TestLocal404
Replace (localIP) with the actual IP that would reach Apache
Doesn't Proxmox have a built-in ACME Client for getting certs? Could that be grabbing these inbound requests instead of your Apache?
Then I wouldn't be making an AAAA record with it until you know it can work.
