Hello,
I'm having trouble with Certbot while trying to obtain an SSL certificate for my domains. Here’s the error message I'm encountering:
////////////////////////////////// error border
Domain: example.pro
Detail: 2606:4700:3030::6815:acf: Invalid response from http://example.pro/.well-known/acme-challenge/m_4SlcCY3wtmYC0xk4sNBxHUXjDlK3REFgaJej-Yx4I: 522
Domain: www.example.pro
Detail: 2606:4700:3032::ac43:befe: Invalid response from http://www.example.pro/.well-known/acme-challenge/8eIUlXAqWe2JJTnOYukDMtOqzas7di46P2BMECR2hiI: 522
Additional Information:
- My WordPress site is enabled at https://example.pro.
- I am using Apache as my web server.
- I’ve checked that the domains point to my server, and it is accessible from the internet.
Actions Taken:
- Ensured the domains are correctly pointing to my server.
- Verified that Apache is configured to serve files from the
.well-known/acme-challengedirectory.
Questions:
- What steps can I take to resolve this issue?
- How can I ensure that Apache serves the challenge files correctly?
- Are there any specific configurations or logs I should review?
Any guidance or suggestions would be greatly appreciated!
Thank you.
I also need help hosting a Next.js application on the same droplet where my WordPress site is located. I've been struggling with this for the past two days and could use some guidance.
Issues I'm Facing:
- Configuration of Apache for serving Next.js
- Setting up SSL certificates correctly for both WordPress and Next.js
If anyone has experience with this setup or can offer advice on resolving these issues, your help would be greatly appreciated!
Thank you!
