Again challenge issue on nginx and duckdns
seagull-home.duckdns.org
certbot renew --dry-run
Processing /etc/letsencrypt/renewal/seagull-home.duckdns.org.conf
http-01 challenge for seagull-home.duckdns.org
Challenge failed for domain seagull-home.duckdns.org
Attempting to renew cert (seagull-home.duckdns.org) from /etc/letsencrypt/renewal/seagull-home.duckdns.org.conf produced an unexpected error: Some challenges have failed.. Skipping.
/etc/letsencrypt/live/seagull-home.duckdns.org/fullchain.pem (failure)
    Domain: seagull-home.duckdns.org
    Type: connection
    Detail: Fetching
    http://seagull-home.duckdns.org/.well-known/acme-challenge/HCCGRxgTWKMSPqWbtydTKmGLWiQrDq_tiwc6BEa_cPg:
    Error getting validation data
nginx
Ubuntu 18.04.5
no
certbot 1.9.0
I'm unable to renew, since challenge file always change, how could I configure nginx to always respond with http 200 ? Currently respond as 404 not found
There seems to be some issue with the current IP address (82.56.24.58) when connecting to port 80:
It responds with a "No route to host" error:
osiris@server ~ $ telnet seagull-home.duckdns.org 80
Trying 82.56.24.58...
telnet: connect to address 82.56.24.58: No route to host
root@server ~ # traceroute -T -p 80 seagull-home.duckdns.org
15  host-82-56-24-58.retail.telecomitalia.it (82.56.24.58)  34.037
ms !X  36.944 ms !X  34.436 ms !X
All this while port 443 works nicely.
Your firewall is probably blocking port 80.
