Adding domain to existing ip running two SSL certificates
Hi there !
First of all thanks a lot to letsencrypt which I’ve been using for another domain (outfired.com) and which has worked perfectly !
I’ve been trying to add a new domain described below, but I’m getting a few troubles !
Both domains have DNS records A towards the same IP.
Outfired.com works perfectly, I’m trying to add the below to it. (have a 2nd certificate for the new domain name and run 2 VirtualHosts in apache to serve the 2 websites)
My domain is: onceuponatime.co.uk
I ran this command: sudo certbot --apache -d onceuponatime.co.uk
http-01 challenge for onceuponatime.co.uk
Waiting for verification…
Failed authorization procedure. onceuponatime.co.uk (http-01): urn:ietf:params:acme:error:dns :: DNS problem: SERVFAIL looking up A for onceuponatime.co.uk
_ - The following errors were reported by the server:_
_ Domain: onceuponatime.co.uk_
_ Type: None_
_ Detail: DNS problem: SERVFAIL looking up A for onceuponatime.co.uk_
Apache 2.2
Linux Debian 9
My domain provider:
google domains
From my initial investigations, it looked like DNSSEC might be the issue so I enabled it - it made no difference.
Any ideas ?
DNS resolution issues are often due to DNSSEC problems, but this one isn’t. According to the TLD, onceuponatime.co.uk uses these nameservers:
onceuponatime.co.uk.    172800  IN      NS      ns0.clara.net.
onceuponatime.co.uk.    172800  IN      NS      ns1.clara.net.
onceuponatime.co.uk.    172800  IN      NS      ns2.clara.net.
They all respond with a REFUSED error code, meaning they don’t host the domain.
Either the NS records are pointing to the wrong DNS service, or the DNS service deactivated the zone or is malfunctioning.
Edit: By the way, the domain’s registrar is also Claranet.
Thanks a lot mnordhoff !
I’ll try and change the nameservers to setup the same ones as my other domain ! Will let you know if it works.
https://dnsspy.io/scan/onceuponatime.co.uk
Shows all three nameservers as:
“Non-responsive nameservers”
Thanks again Mark !
After changing the nameservers it worked like a charm.
Have a wonderful day !
