Add virtual host for port 80
My domain is: casper.defiancecityschools.org
It produced this output:Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.
My hosting provider, if applicable, is: There is no hosting provider. This is a JamfPro server
I am trying to get a SSL cert for our Jamf Pro server and am running into the Virtual Host error. I'm not sure how to configure a virtual host and so far JAMF has been no help. Any help would be appreciated.
Welcome to the Let's Encrypt Community :slightly_smiling_face:
I'll try to help you out here. While I'm not familiar with Jamf Pro, I am familiar with Apache.
I've noticed that both ports 80 (http) and 443 (https) appear to be closed for casper.defiancecityschools.org. This could be due to the VirtualHost being missing in Apache. My question is though, do you ever actually have an Apache webserver operating over http at all? Put another way, do you ever see a webpage in a browser when you visit casper.defiancecityschools.org? If not, there's another way to use certbot to get a certificate that I can show you.
Try this for me if you would, and let me know the result:
sudo certbot certonly --standalone -d "casper.defiancecityschools.org" --dry-run
Griffith,
Thank you for the reply. I've been at this for too many hours and am still have no luck - my strength is not web programing/server maintenance. When I read your post it started thinking that my issue might be a port issue as the actual address necessary to log into the site is casper.defiancecityschools.org:8443. Based on my limited knowledge this makes sense that I am having problems.
And I did run the command that you asked about. Here is the output: --dry-run currently only works with the 'certonly' or 'renew' subcommands ('run')
:man_facepalming:
I forgot to put certonly in the command. Sorry about that. I updated the command in my previous post.
Griffin,
Here is the output:
Account registered.
Simulating a certificate request for casper.defiancecityschools.org
http-01 challenge for casper.defiancecityschools.org
Problem binding to port 80: Could not bind to IPv4 or IPv6.
Casper:conf.d administrator$"
