How to resolve: "Please add a virtual host for port 80"
My domain is: timster.net
Crosstrek:~ zzzz$ sudo certbot --apache
Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.
MAMP Pro 5.7 - using Apache
MacOS High Sierra 10.13.6 (17G12034)
my machine, on my desk in front of me
I am the admin and have run the Certbot install commands up to the point of the one listed above in Terminal.
Yes, MAMP Pro 5.7
certbot 1.3.0
Website works and can connect via HTTP and HTTPS. Firewall set to listen on ports 80, 443
Perhaps it would be better if certbot would work without a virtualhost, but do you have a reservation against just wrapping the important directives around a <VirtualHost> section to your Apache configuration?
Hi;
Thanks, but I’m really not sure what you’re asking. All I am trying to
do is get a cert, and I get the error in the process. I use MAMP Pro for MacOS specifically because I don’t want to get into the minutiae of Apache configuration. That said, “wrapping the important directives around a …” doesn’t really give me any actionable information.
What, specifically can I edit, copy, delete, change <etc.> to fix the error that is generated by Certbot?
Thank you.
