mmfacc
October 24, 2023, 4:30pm
1
POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/277007748486 failed: cURL error 35: TCP connection reset by peer (see libcurl - Error Codes ) for https://acme-v02.api.letsencrypt.org/acme/authz-v3/277007748486
OR
Could not obtain directory: cURL error 56: TCP connection reset by peer (see libcurl - Error Codes ) for https://acme-v02.api.letsencrypt.org/directory
Manually runnning curl is up and down. When is not working:
curl -Ikv https://acme-v02.api.letsencrypt.org/directory
About to connect() to acme-v02.api.letsencrypt.org port 443 (#0 )
Trying 172.65.32.248...
Connected to acme-v02.api.letsencrypt.org (172.65.32.248) port 443 (#0 )
Initializing NSS with certpath: sql:/etc/pki/nssdb
NSS error -5961 (PR_CONNECT_RESET_ERROR)
Closing connection 0
curl: (35) TCP connection reset by peer
This happens on newer and older NSS packages
Any idea?
Hello @mmfacc , welcome to the Let's Encrypt community.
Maybe related to this:
Bruce5051:
Very unlikely. A faulty local network routing would be failing always.
@mmfacc Do these curl requests work reliably?
curl -I https://www.cloudflare.com
curl -I https://www.google.com
mmfacc
October 24, 2023, 4:48pm
5
randomly
curl: (35) Network file descriptor is not connected
mmfacc
October 24, 2023, 4:51pm
6
curl -I https://www.google.com wors most reliably
Looks like intermittent connective issues between your system and the Internet.
Where, hard to say at this point.
But does google still fail some times? Because then yes a general comms issue connecting outbound from your system.
If google was 100% but the other two sometimes failed that's different. Because Let's Encrypt API also uses Cloudflare.
mmfacc:
wors
I took that as a minor type for worst, and assumed it meant
"curl -I https://www.google.com/ being the least reliable"
rg305
October 24, 2023, 5:59pm
10
I read it as was.
I guess my automatic autocorrection worked bess - lol
rg305
11
Are you on WiFi?
Please show these outputs:
traceroute -T -p 443 www.google.com
traceroute -T -p 443 acme-v02.api.letsencrypt.org
mmfacc
October 24, 2023, 6:38pm
12
Doing some test it looks like the problem with cloudflare as curl google always works.
At this point it looks to be some kind upstream provider routing issue.
Also noticing raising Error Counts on our LE Monitoring ... guess there is a Problem on LE side since about 8:10pm ...
MikeMcQ
October 24, 2023, 7:08pm
14
@futureweb You should probably start a new thread with your detailed observations. The problems might overlap but possibly not.
Ccurrently not on my PC, just had a quick look into the boards on my mobile phone to check If problems are reported as my monitoring reported elevated LE Renewal Errors ...
If they persist when I'm back on my PC I will open own Thread with more Details (on phone too much hassle to aggregate all needed info ... also no actual threat on my side as we Queue all create/renewals on failure)
