I'm having a sequence of two situations that I had not encountered in N previous setups. I hope you can provide a hint where to look for.
First comes this:
Unable to read ssl_module file; not disabling session tickets.
Which looks important as ssl_module is required for https operations, but not to produce the next error:
Domain: mail.idt.mx
Type: connection
Detail: 200.23.130.34: Fetching http://mail.idt.mx/.well-known/acme-challenge/8pDwpZJTrhsgejGVPJX7gTspBAHXWZvsest5jmoFpjg: Connection refused
My web server and OS are:
root@mail:~ # apachectl -v
Server version: Apache/2.4.57 (FreeBSD)
Server built: unknown
root@mail:~ # uname -a
FreeBSD mail.idt.mx 13.2-RELEASE FreeBSD 13.2-RELEASE releng/13.2-n254617-525ecfdad597 GENERIC amd64
root@mail:~ # certbot --version
certbot 2.6.0
CODE:
root@mail:~ # curl -i http://mail.idt.mx
HTTP/1.1 200 OK
Date: Mon, 07 Aug 2023 14:32:01 GMT
Server: Apache
Last-Modified: Sat, 05 Aug 2023 21:20:34 GMT
ETag: "2d-60233957a4eda"
Accept-Ranges: bytes
Content-Length: 45
Content-Type: text/html
It works!
root@mail:~ # certbot --apache
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: mail.idt.mx
Requesting a certificate for mail.idt.mx
Domain: mail.idt.mx
Type: connection
apache24 not running? (check /var/run/httpd.pid).
Unable to restart apache using ['apachectl', 'graceful']
Encountered exception during recovery: certbot.errors.MisconfigurationError: Error while running apachectl graceful.
root@mail:~ #
...and apache crashes or doesn't come back up.
