I have a client with 250 domains.
I understand there is a 100 domain limit when creating a cert.
Please give us the ability to enter a range when certbot lists out the available domains that need SSL.
... like 1-100, 101-200, 201-250
Thanks in advance.
Have pagination for for the certbot certificates
command sounds like it could be useful. You should file a feature request on the Certbot repository that they can review and consider implementing.
I believe @letsencrypter means the step where one can select the domains to be included in a certificate in one of the first steps of acquiring a certificate (if an installer plugin is used that is).
Although that difference doesn't really make a difference regarding your advice to open an issue on Github
Maybe some AI logic too like:
1-
[to imply start at one and take as many as you can until the numbers run out (or you fill up)]
hmm...
Maybe that's just " * " in that example.
OK, how about:
201-
201+
201~
201^
