My domain is corequery.uk and I am trying to install SANS certificates on Fedora 30 with Apache 2.4 and full root access (command line). The whole process just hangs with the following log file output:
2019-07-04 21:18:25,129:DEBUG:certbot.main:certbot version: 0.35.1
2019-07-04 21:18:25,129:DEBUG:certbot.main:Arguments: ['--domains', 'exstocktra.de,insurgent.info,corequery.uk', '--apache']
2019-07-04 21:18:25,129:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2019-07-04 21:18:25,143:DEBUG:certbot.log:Root logging level set at 20
2019-07-04 21:18:25,143:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2019-07-04 21:18:25,144:DEBUG:certbot.plugins.selection:Requested authenticator apache and installer apache
2019-07-04 21:18:37,458:DEBUG:certbot_apache.configurator:Apache version is 2.4.39
2019-07-04 21:19:09,817:ERROR:certbot.log:Exiting abnormally:
File "/usr/bin/certbot", line 11, in <module>
load_entry_point('certbot==0.35.1', 'console_scripts', 'certbot')()
File "/usr/lib/python3.7/site-packages/certbot/main.py", line 1379, in main
File "/usr/lib/python3.7/site-packages/certbot/main.py", line 1112, in run
installer, authenticator = plug_sel.choose_configurator_plugins(config, plugins, "run")
File "/usr/lib/python3.7/site-packages/certbot/plugins/selection.py", line 223, in choose_configurator_plugins
authenticator = installer = pick_configurator(config, req_inst, plugins)
File "/usr/lib/python3.7/site-packages/certbot/plugins/selection.py", line 24, in pick_configurator
(interfaces.IAuthenticator, interfaces.IInstaller))
File "/usr/lib/python3.7/site-packages/certbot/plugins/selection.py", line 105, in pick_plugin
verified.prepare()
File "/usr/lib/python3.7/site-packages/certbot/plugins/disco.py", line 253, in prepare
return [plugin_ep.prepare() for plugin_ep in six.itervalues(self._plugins)]
File "/usr/lib/python3.7/site-packages/certbot/plugins/disco.py", line 253, in <listcomp>
File "/usr/lib/python3.7/site-packages/certbot/plugins/disco.py", line 131, in prepare
self._initialized.prepare()
File "/usr/lib/python3.7/site-packages/certbot_apache/configurator.py", line 263, in prepare
self.parser = self.get_parser()
File "/usr/lib/python3.7/site-packages/certbot_apache/override_fedora.py", line 55, in get_parser
self.version, configurator=self)
File "/usr/lib/python3.7/site-packages/certbot_apache/override_fedora.py", line 86, in __init__
super(FedoraParser, self).__init__(*args, **kwargs)
File "/usr/lib/python3.7/site-packages/certbot_apache/parser.py", line 56, in __init__
self.update_runtime_variables()
File "/usr/lib/python3.7/site-packages/certbot_apache/override_fedora.py", line 91, in update_runtime_variables
super(FedoraParser, self).update_runtime_variables()
File "/usr/lib/python3.7/site-packages/certbot_apache/parser.py", line 145, in update_runtime_variables
self.update_modules()
File "/usr/lib/python3.7/site-packages/certbot_apache/parser.py", line 191, in update_modules
matches = self.parse_from_subprocess(mod_cmd, r"(.*)_module")
File "/usr/lib/python3.7/site-packages/certbot_apache/parser.py", line 205, in parse_from_subprocess
stdout = self._get_runtime_cfg(command)
File "/usr/lib/python3.7/site-packages/certbot_apache/parser.py", line 221, in _get_runtime_cfg
stdout, stderr = proc.communicate()
File "/usr/lib64/python3.7/subprocess.py", line 939, in communicate
stdout, stderr = self._communicate(input, endtime, timeout)
File "/usr/lib64/python3.7/subprocess.py", line 1681, in _communicate
ready = selector.select(timeout)
File "/usr/lib64/python3.7/selectors.py", line 415, in select
fd_event_list = self._selector.poll(timeout)
KeyboardInterrupt
