A certificate is not issued for a subdomain
My domain is: dev.tv.mk.ru
I ran this command: certbot certonly --authenticator dns-nicru --dns-nicru-credentials /etc/letsencrypt/credentials.ini --dns-nicru-propagation-seconds 300 --server https://acme-v02.api.letsencrypt.org/directory --agree-tos --rsa-key-size 4096 -d 'dev.tv.mk.ru'
It produced this output: Certbot failed to authenticate some domains (authenticator: dns-nicru). The Certificate Authority reported these problems:
Domain: dev.tv.mk.ru
Detail: No TXT record found at _acme-challenge.dev.tv.mk.ru
Hint: The Certificate Authority failed to verify the DNS TXT records created by --dns-nicru. Ensure the above domains are hosted by this DNS provider, or try increasing --dns-nicru-propagation-seconds (currently 300 seconds).
The operating system my web server runs on is (include version): ubuntu
My hosting provider, if applicable, is: nic.ru
no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.9.0
Welcome @Andrey
The first thing you should do is review and fix the errors and warnings shown by the DNSViz site below.
Also, are all of your name servers updated by that dns-nicru authenticator you are using? I did not lookup each of your DNS Servers but some of their names are very different making me think they are different providers and maybe not updated by dns-nicru script. All of your DNS Servers need to have the TXT records for the challenge to succeed.
https://dnsviz.net/d/dev.tv.mk.ru/dnssec/
You helped me a lot and I issued the certificate on the test server. But in production, I get this error
!!!!certbot: error: unrecognized arguments: --dns-nicru-credentials /etc/letsencrypt/credentials_avtovzglyad.ini --dns-nicru-propagation-seconds 700!!!!
I run the following command
certbot certonly --authenticator dns-nicru --dns-nicru-credentials /etc/letsencrypt/credentials_avtovzglyad.ini --dns-nicru-propagation-seconds 700 --server https://acme-v02.api.letsencrypt.org/directory --agree-tos --rsa-key-size 4096 --cert-path /etc/letsencrypt/live/avtovzglyad.ru-test/cert.pem --key-path /etc/letsencrypt/live/avtovzglyad.ru-test/privkey.pem --chain-path /etc/letsencrypt/live/avtovzglyad.ru-test/chain.pem --fullchain-path /etc/letsencrypt/live/avtovzglyad.ru-test/fullchain.pem -d avtovzglyad.ru -d admin.avtovzglyad.ru -d avtovz.ru -d www.avtovz.ru -d www.avtovzglyad.ru
certbot plugins
  • apache
    Description: Apache Web Server plugin
    Interfaces: IAuthenticator, IInstaller, IPlugin
    Entry point: apache = certbot_apache.entrypoint:ENTRYPOINT
  • certbot-dns-nicru:dns-nicru
    Description: Obtain certificates using a DNS TXT record (if you are using nic.ru
    for DNS).
    Entry point: dns-nicru = certbot_dns_nicru.dns_nicru:Authenticator
pip show certbot-dns-nicru
Version: 1.0.2
Summary: This plugin for certbot, configures a DNS TXT record to respond to a dns-01 challenge using the nic.ru Remote REST API.
Home-page: GitHub - shizacat/certbot-dns-nicru: A certbot plugin for enabling DNS authentication with nic.ru
Author: Alexey Matveev
Author-email:
License:
Requires: acme, certbot, requests, setuptools, sh-nic-api, zope.interface
Required-by:
Are you running the same version of Certbot on your test server as this one?
There were some changes in Certbot V2 on how plugins operated. I don't remember the details other than there were some.
I have never seen that DNS plugin used on this forum. You may need to ask this on the github for it. Or, wait for someone here with more info about Certbot versions and DNS plugins.
I've dealt with the last mistake.
But now a new one)
Add record error: Code: 4096. Access forbidden
That sounds like your Certbot nicru plugin could not update the DNS server(s) because of incorrect security credentials.
You still have errors and warnings on your DNS tree per DNSViz that I linked earlier. You may need to fix those.
Or, post on the github for this plugin about this.
If you don't get any response on that plugin github you might look at using the ACME Client acme.sh instead of Certbot. It also supports the nic.ru DNS api.
acme.sh/dnsapi/dns_nic.sh at master · acmesh-official/acme.sh · GitHub
