400 Error issue: Validation error
My domain is: betheldentalsingapore.com
I ran this command: I used FastComet Cpanel to issue the SSL Certificate
There was a problem processing your request
Error issuing certificate
Failed to issue certificate
Updating challenge for mail.betheldentalsingapore.com: acme: error code 400 "urn:ietf:params:acme:error:connection": 3.33.244.179: Fetching http://mail.betheldentalsingapore.com/.well-known/acme-challenge/VlbS09K7Okfpr7ENL8BkiQUtrDNdYRjgP4bepj4Vtc0: Error getting validation data (order URL: https://acme-v02.api.letsencrypt.org/acme/order/1742306432/272167039152)
My hosting provider, if applicable, is: Fast Comet
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Yes, Cpanel 120.0.5
Appreciate any help, this is my first time setting up. I was able to complete for my main domain, but not for the sub domain.
Thanks!
I can't connect to your domain and neither can the Let's Debug test site or the Let's Encrypt Staging system. I cannot connect with your main domain or the www or mail subdomains.
This sounds like a problem better asked of your hosting provider. They setup the cPanel system for their hosting and know best how that should work.
I don't see that a Let's Encrypt cert was ever issued for your main domain either. I see a GoDaddy cert issued today for your main domain and www subdomain. I think Fast Comet should be able to help you. It is what you pay for with full service hosting.
thanks MikeMcQ, appreciate your help!
I see your index and it is secured!
A records for betheldentalsingapore.com: ['172.104.165.217']
AAAA records for betheldentalsingapore.com: No record found
MX records for betheldentalsingapore.com: ['10 sgpro5.fcomet.com.']
NS records for betheldentalsingapore.com: ['ns2.sgpro5.fcomet.com.', 'ns1.sgpro5.fcomet.com.']
CNAME records for betheldentalsingapore.com: No record found
TXT records for betheldentalsingapore.com: No record found
SOA records for betheldentalsingapore.com: ['ns1.sgpro5.fcomet.com. root.sgpro5.fcomet.com. 2024052401 3600 1800 1209600 86400']
:smiley:
yes thank you i was able to get support to assist. thanks guys
