Zimbra letsencrypt experts/specialists?
My domain is:gw2.network1.ca
I ran this command:/opt/zimbra/bin/zmcertmgr verifycrt comm /opt/zimbra/ssl/zimbra/commercial/commercial.key /opt/zimbra/ssl/letsencrypt/cert.pem /opt/zimbra/ssl/letsencrypt/chainZimbra.pem
It produced this output:** Verifying '/opt/zimbra/ssl/letsencrypt/cert.pem' against '/opt/zimbra/ssl/zimbra/commercial/commercial.key'
Certificate '/opt/zimbra/ssl/letsencrypt/cert.pem' and private key '/opt/zimbra/ssl/zimbra/commercial/commercial.key' match.
** Verifying '/opt/zimbra/ssl/letsencrypt/cert.pem' against '/opt/zimbra/ssl/letsencrypt/chainZimbra.pem'
ERROR: Unable to validate certificate chain: C = US, O = Let's Encrypt, CN = E8
error 2 at 1 depth lookup: unable to get issuer certificate
error /opt/zimbra/ssl/letsencrypt/cert.pem: verification failed
The operating system my web server runs on is (include version):ubuntu 20.04 LTS Focal Fossa
I'm using a control panel to manage my site (no, or provide the name and version of the control panel):no, command line only
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 2.6.0
IIRC old version of zimbra wants rsa key.
https://wiki.zimbra.com/wiki/Installing_a_LetsEncrypt_SSL_Certificate
Support for ECDSA TLS (elliptic curve cryptography ECC) certificates has been added to Zimbra zmcertmgr from Zimbra versions 10.0.6, Joule-8.8.15-Patch-45, Kepler-9.0.0-Patch-38.
excellent. you are correct. I used ISRG-X2.pem, I did the chain.pem again with the ISRG-X1.pem certificate, and no issues. Thank you. Thank you ( I know, I intentionally repeated myself)
If you're on a Zimbra version before 10.1, you can apply ZBUG-3135 directly to /opt/zimbra/bin/zmcertmgr, the fix is straightforward:
thank you, I really should be updating this version. I have been negligent in staying current with the nuances.
You saved me a lot of time last evening, I am very grateful for your advice. I intend to look at some of the alternatives to Zimbra going
forward as Syncor fees do not make an upgrade financially viable for me. Do you have any
recommendations ?, thank you again, I will get that patch and add in the very near future.
Blake Patton
