First of all, I appreciate everything Let'sEncrypt does for the world!!! My frustrations are born out of my own incompetence!!!!
My domain is: mdttexas.com
I ran this command: I updated my current Cert to add this domain to my 10 others and requested new Cert through the Lets Encrypt tool in VirtualMin
Renewing an existing certificate for soberscove.com and 10 more domains
Domain: mdttexas.com
Type: connection
Detail: 2600:3c02::f03c:93ff:fe96:4d77: Fetching https://mdttexas.com/.well-known/acme-challenge/aonq59pxImhPjl4TPAq_k-XStBIW_KwptpagZR1h8UE: Error getting validation data
Domain: www.mdttexas.com
Type: connection
Detail: 2600:3c02::f03c:93ff:fe96:4d77: Fetching https://www.mdttexas.com/.well-known/acme-challenge/XcW-nJx_jgBh_GksVladaGdR3phCZY4WNwAxPLE0I-c: Error getting validation data
My web server is (include version): Apache 2
The operating system my web server runs on is (include version): Ubuntu Linux 20.04.6
My hosting provider, if applicable, is: Linode
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): VirtualMin
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 3.1.0
I have to wrestle and fight and wait and hope and pray every three months that my certs will renew. I seem to get them to work, but there are always tons of errors, nothing works first time, and even when it does work, it says that it doesn't - then I have to go look at the actual sites to confirm that it does.
- I have a WordPress Multi-Site set-up that runs on a VirtualHost that I admin with VirtualMin
- I have about 10 domains, I request the SSL cert each time for all of them, seems to work eventually. Renewing does not really seem to work.
- Adding a NEW domain is a coin flip, sometimes they work right away, sometimes not. I CAN see the well known ACME folders, but CertBot doesnt seem to be putting the challenges there, I made the folders 777 for time being
Basically I think that my Apache config file, CertBot settings, SSL settings, etc have just slowly gotten out of whack over last 8 years or so.
I have total access and control over the server, both with Virtualmin and root SSH if needed. It's a pretty basic web hosting setup, there is just something not quite right.
I would like to work with somebody to help me update and correctly align everything, and then help me how to proceed in a way to allow for easy additions and renewals. I think it should take maybe an hour or so tops, and I am happy to pay.
Please contact me (don't worry, I will get the message) via
trash
at
cloudcitydigital.com
...if you have a working knowledge of Apache / VirtualMin / Certbot / Let's Encrypt.
Again, happy to pay for an hour of your time.
Thanks!
Stephen
