WSS with SSL certificate not working
My domain is : healthieshield.com
I have installed my system on ubuntu 18.04 LTS , and plesk (Version Plesk Obsidian v18.0.27_build1800200522.12) is insalled.
Hosting provideer is soyoustart and domain bought from namecheap.
From plesk panel I have binded the let’s encrypt certificate (with wildcard). Which I have used for main website, api service and internal MQTT service.
For main website and API service (subdomain api.healthieshield.com), SSL working properly.
But when I have bind certificate in mqtt broker (aedes mqtt broker), it shows issue. From website (healthieshield.com), when trying to connect on wss (wss://www.healthieshield.com:3001/) it shows below error:
WebSocket connection to ‘wss://www.healthieshield.com:3001/’ failed: Error in connection establishment: net::ERR_CERT_AUTHORITY_INVALID
We have also tried below command, and it shows desired output:
echo | openssl s_client -connect healthieshield.com:443 -servername healthieshield.com 2>/dev/null | awk ‘/Certificate chain/,/—/’
Certificate chain
0 s:CN = srv01.healthieshield.com
i:C = US, O = Let’s Encrypt, CN = Let’s Encrypt Authority X3
1 s:C = US, O = Let’s Encrypt, CN = Let’s Encrypt Authority X3
i:O = Digital Signature Trust Co., CN = DST Root CA X3
We have tried to solve it but we did not get any solution.
This doesn't work because the issue is on WebSocket, which as per your output is on port 3001.
The correct command is:
openssl s_client -connect www.healthieshield.com:3001 -servername healthieshield.com
I believe your WebSocket application doesn't read Plesk's certificate database (as it might not even passthrough Plesk Nginx/apache), so you'll need to do some custom work to change WebSocket address (to go through Plesk/https) and make sure Plesk proxy those requests (via Nginx)
You can try this: ubuntu - NGINX Proxy_Pass to websocket server on a Plesk Server - Server Fault (Disclaimer: I found this online so be cautioous when you apply any solutions.)
Hi @pkachhia
your command checks the non-www version.
But your www version has a self signed certificate - https://check-your-website.server-daten.de/?q=healthieshield.com%3A3001
E=sysadmin@slscorp.com, CN=local.mqtt, OU=TEMPie, O=SLS, L=Anand, S=Gujarat, C=IN
	01.06.2020
	09.01.2026
expires in 2040 days
So there is no Letsencrypt certificate.
Same with OpenSsl.
Thanks @JuergenAuer,
We have updated the certificate, and checked, issue resolved.
Now it working properly.
Can you help me to understand that, if the ceriticate will auto update after 3 month of time, will the name stored on linux server will change ?
I don't know.
A restart of that service may be always required to use the new certificate.
But
  • you can use symlinks (if that program understands symlinks) (or)
  • you can copy the certificate
If you have the certificate copied, you have to do that again.
Thanks for update @JuergenAuer,
I think for me 1st option with symlinks is better, let’s try at our end.
