Issue using webscokets over wss
Hi All,
I have managed to just get websockets working on my server. i have a page Document that connects to a nodejs app located on ws.trivia.house.
when i switch to use wss at Document the service fails althouh i have a letencrypt certificate covering wildcard of *trivia.house and covering ws.trivia.house. can someone help me please?
the failure is:
WebSocket connection to 'wss://ws.trivia.house:8080/' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
trivia.house
(websocket subdomain) ws.trivia.house
I can login to a root shell on my machine
I'm using a Plesk to manage my site
Hi @pundabuyer, and welcome to the LE community forum :slight_smile:
I have no way of troubleshooting "wss://".
That said, I do have some questions.
Correct me where I'm wrong:
HTTP
insecure = http://trivia.house/client.html
secure   = https://trivia.house/clientssl.html
WEB SOCKET
insecure = wss://ws.trivia.house:8080/
secure   = wss://ws.trivia.house:8080/  ???
  OR
secure   = wss://ws.trivia.house:8443/  ???
Are you trying to use the same socket port for both secure and insecure connections?
Are all these ports accessible from the Internet?
How do you test?
Hi!
Thank you for responding.
So yes, let me confirm:
HTTP
insecure call to web socket = http://trivia.house/client.html
secure call to web socket = https://trivia.house/clientssl.html
WEB SOCKET
insecure socket = ws://ws.trivia.house:8080/
secure socket = wss://ws.trivia.house:8080/
I only want to use the socket for secure connections but yes it can be used for both i believe - i didnt realise there was a difference as its the connecting protocol that differs not the js app. should it be using a different port?
The socket app is only running on port 8080 and yes it is accessible.
If you go to http://trivia.house/client.html and use the inspect function to see console you will see success
Do the same for https://trivia.house/clientssl.html and you will see failures.
Can anyone help more please?
I suggest reading
I see this with Windows 10 Chrome Version 110.0.5481.78 (Official Build) (64-bit)
And with curl
$ curl -Ii http://trivia.house/client.html
HTTP/1.1 200 OK
Server: nginx
Date: Mon, 13 Feb 2023 17:28:08 GMT
Content-Type: text/html
Content-Length: 682
X-Accel-Version: 0.01
Last-Modified: Mon, 13 Feb 2023 17:01:12 GMT
ETag: "2aa-5f497cb543af4"
Accept-Ranges: bytes
Vary: Accept-Encoding
X-Powered-By: PleskLin
$ curl -Ii https://trivia.house/client.html
HTTP/2 200
server: nginx
date: Mon, 13 Feb 2023 17:28:28 GMT
content-type: text/html
content-length: 682
x-accel-version: 0.01
last-modified: Mon, 13 Feb 2023 17:01:12 GMT
etag: "2aa-5f497cb543af4"
accept-ranges: bytes
vary: Accept-Encoding
x-powered-by: PleskLin
That seems problematic.
You should separate the secure from the insecure socket.
I'm not that familiar with WebSockets, but indeed, that does look problematic.
Maybe you can explain a little bit more about how you've set up that WebSockets service. I'm assuming Node.js (ugh..) from your initial post? But how exactly?
Hi all thanks for all the replies. I should have been a little clearer.. I was only using unsecure sockets whilst i set up now i only want to use secure so staying on port 8080 should be ok. You can ignore the 'ws' version.
For context, it is a js file that creates the socket server running on nodejs.
the code in the js app is:
var WebSocket = require('ws');
var server = new WebSocket.Server({port: 8080});
console.log('Listening on port 8080...');
server.on('connection', function(socket) {
console.log('Client has connected');
socket.on('message', function(message) {
console.log('Received from client: %s', message);
socket.send('Server received message from client: ' + message);
I'm not that familiar with Node.js, but I'm not seeing any TLS configuration in that piece of code?
If you secure your webserver on port 443, that doesn't mean your Node.js service automatically will too.
I found further code that could work but I don't know where to find the cert and key files?
const WebSocket = require("ws").Server;
const HttpsServer = require('https').createServer;
const fs = require("fs");
server = HttpsServer({
cert: fs.readFileSync("??"),
key: fs.readFileSync("??")
socket = new WebSocket({
server: server
I would suggest the same location that your nginx server is getting them from.
nginx refers to the same file for key and cert
Please show the nginx configuration. It usually has the key and cert separately.
what is the file i should be looking at? I'm not familiar with nginx
/etc/nginx/nginx.conf
There are better places to get familiar with nginx than this forum :wink:
Well, you claim nginx is using the same file for key and cert, so obviously you've looked at something, right? Something with ssl_certificate and (optional) ssl_certificate_key.
