Wrong domain in cert
My domain is: retazosdevida.es
I ran this command: AutoSSL in my CWP
It produced this output: Domain in cert is other than SSL’d
My web server is (include version): 93.189.88.100
The operating system my web server runs on is (include version): CentOS 7.0 (64 Bit)
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Yes, CWP
Hi @PereVinyeta
check the output of https://check-your-website.server-daten.de/?q=retazosdevida.es
You have created three certificates:
Let's Encrypt Authority X3 2019-12-26 2020-03-25 retazosdevida.es, www.retazosdevida.es - 2 entries duplicate nr. 3
Let's Encrypt Authority X3 2019-12-26 2020-03-25 retazosdevida.es, www.retazosdevida.es - 2 entries duplicate nr. 2
Let's Encrypt Authority X3 2019-12-26 2020-03-25 retazosdevida.es, www.retazosdevida.es - 2 entries duplicate nr. 1
Let's Encrypt Authority X3 2019-11-23 2020-02-21 cpanel.retazosdevida.es, mail.retazosdevida.es, retazosdevida.es, webdisk.retazosdevida.es, webmail.retazosdevida.es, www.retazosdevida.es - 6 entries
And your Plesk port 8443
|www.retazosdevida.es|8443|Plesk Administration (https)|open|https://www.retazosdevida.es:8443/
Http-Status: 200|Certificate is valid|
uses that certificate.
Looks like you have to install the existing certificate manual with your CWP, so the
CN=brisagrafics.com
	24.11.2019
	22.02.2020
expires in 58 days	brisagrafics.com - 1 entry
isn't longer used. Perhaps you have to create a vHost.
PS: Your https://www.retazosdevida.es:8443/ isn't a Plesk, there is your website.
Looks like your website uses the wrong port 8443.
