Well... You might want to use different certificates for different names.
Also, you don't need different virtualhosts, just one with a lot of aliases. I would use Caddy.
Got it. Now I understand Create the vhost in sites/available/ and then activate it. That's what I did. I think I just misunderstood originally.
I'll have to check out this Caddy you speak of. it look interesting at first glance for my type of setup
The OP can use a single virtualhost with many aliases if apache doesn't terminate SSL.
Because they were manually editing the certificate domains and onboarding/offloading domains on a regular basis, we suggested multiple virtualhosts - each for a single domain - so Certbot could automatically manage domain-specific SSL certificates.
Using Caddy or terminating SSL before Apache was the initial suggestion. The OP is familiar with Apache though.
