My domain is: boosterclubnetwork.com madisonboosters.com
My web server is (include version): Apache2
My hosting provider, if applicable, is: Linode VPS
I want to run multisite on a Ubuntu VPS using LAMP. I want to support subsite domains as well as custom URLs. I am using letsencrypt.
I couldn’t figure out my virtualhost file, so I let my friend take a swing at it, now it’s jacked up even worse.
I am having 2 problems.
The url boosterclubnetwork.com (or www.boosterclubnetwork.com) loads a completely different site on the same server.
I get a certificate domain mismatch (this seems to be obviously related to the fact that the wrong site is loading).
<VirtualHost *:80>
# specifies what hostname must appear in the request’s Host: header to
ServerName www.boosterclubnetwork.com
ServerAlias boosterclubnetwork.com
DocumentRoot /var/www/html/boosterclubnetwork.com/public_html
<Directory /var/www/>
AllowOverride All
Require all granted
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =www.boosterclubnetwork.com [OR]
RewriteCond %{SERVER_NAME} =boosterclubnetwork.com
<VirtualHost *:80>
ServerName www.madisonboosters.com
ServerAlias madisonboosters.com
# not required Alias /mysite-2.dev "/home/mysite-2"
<Directory /var/www/html/boosterclubnetwork.com/public_html>
Options Indexes FollowSymLinks Includes ExecCGI
AllowOverride All
Order allow,deny
Allow from all
</Directory>
RewriteEngine on
RewriteCond %{SERVER_NAME} =www.madisonboosters.com [OR]
RewriteCond %{SERVER_NAME} =madisonboosters.com
