Will webroot challenge be performed over HTTPS or HTTP?
When performing a certbot renew with --webroot I was getting the below described error, now I found out the root of the issue was LetsEncrypt performing the challenge via HTTP instead of HTTP, even though on the error is mentioned that it was fetching https://status.upstreampay.com/.well-known/acme-challenge, it was instead fetching http://status.upstreampay.com/.well-known/acme-challenge, which due to NGINX certbot generated config was redirecting with 301, which then was returning the correct value, but still the challenge would fail.
This is the NGINX config that was matching and failing:
    if ($host = status.upstreampay.com) {
    } # managed by Certbot
    listen 80;
    listen [::]:80  ;
    server_name status.upstreampay.com;
My domain is: status.upstreampay.com
I ran this command: certbot certonly --webroot -w /var/www
http-01 challenge for status.upstreampay.com
Using the webroot path /var/www for all unmatched domains.
Challenge failed for domain status.upstreampay.com
   Domain: status.upstreampay.com
   Type:   connection
   Detail: Fetching
   https://status.upstreampay.com/.well-known/acme-challenge/29YzYLF7PuG9_RvhgCzYRkBcdyJYza4DVNPa7ZS-ihI:
   Error getting validation data
My web server is (include version): nginx/1.20.1
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: DigitalOcean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.0.0
It starts at HTTP, but the validation server follows redirects.
refer to your other topic:
"Certbot renew fails even when the challenge HTTP request is working"
