Hi. I originally installed a Letsencrypt certificate using letsencrypt-win-simple for my domain (www.domain.com). The certificate installed correctly and I was able to go to my domain via https://www.domain.com and everything is working fine.
However, I don’t want multiple versions of my site running - http://domain.com, http://www.domain.com, https://domain.com/, and https://www.domain.com. I want to consolidate and do a 301 redirect to https://www.domain.com (this is better for Google because you can avoid duplicate content). So, what I did was add the following redirect rule in my web.config:
<rule name="Redirect non www and non https to https://www.domain.com">
<match url=".*" />
<conditions logicalGrouping="MatchAny">
<add input="{HTTP_HOST}" pattern="^domain.com$" />
<add input="{HTTPS}" pattern="off" />
</conditions>
<action type="Redirect" url="https://www.domain.com/{R:0}" redirectType="Permanent"/>
</rule>
The above rule does what I want, in that it will 301 redirect you to https://www.domain.com even if the user types in http://domain.com, http://www.domain.com, or https://domain.com. However, when I went to test https://domain.com, it gave me an error because I only installed the original Letsencrypt certificate for https://www.domain.com and not https://domain.com.
So, I then ran letsencrypt-win-simple again with the --san parameter: letsencrypt-win-simple --san
Unfortunately, when I did this, it gave me the following error:
The ACME server was probably unable to reach http://domain.com/.well-known/acme-challenge/...
I suppose the reason I got the error above was because of the redirect rule I added to my web.config (refer to the redirect rule I pasted in my web.config above) and the ACME server probably can’t reach http://domain.com because of the 301 redirect. So, I had to disable that rule and run letsencrypt-win-simple again with the --san parameter, This time, it worked. I then re-enabled that rule in my web.config after the successful installation of the SAN certificate. Everything is working fine now.
My 2 questions are:
Because I re-enabled the redirect rule in my web.config to 301 redirect http://domain.com, http://www.domain.com, and https://domain.com to https://www.domain.com, will the letsencrypt-win-simple renewal task in Task Scheduler be able to properly renew my certificate in 60 days? I am not sure because since I re-enabled the redirect rule, I am worried that I will get the same “The ACME server was probably unable to reach http://domain.com/.well-known/acme-challenge/…” message on the date of the renewal.
Is there a way for me to test an early renewal using the letsencrypt-win-simple renewal task in Task Scheduler? I don’t want to wait 60 days to see if the renewal succeeds or not. I would like to test it in the next few hours (or tomorrow if I need to wait until the next day) to see if the letsencrypt-win-simple renewal task in Task Scheduler is able to properly renew the certificate.
