Wildcard SSL Not Active Even After Certbot Issued Certificate
I installed a certificate using google dns plugin but my site still won’t work (It’s a .dev domain so HSTS is preloaded and it must have SSL to even load up)
My domain is: botivity.dev
I ran this command: sudo certbot certonly --dns-google --dns-google-credentials ~/.secrets/certbot/google.json -d 'botivity.dev' -d '*.botivity.dev'
It produced this output: image
My web server is (include version): Apache/2.4.38
The operating system my web server runs on is (include version): Debian 10 Buster
My hosting provider, if applicable, is: Google Cloud Platform
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
Also:
If i run sudo certbot certificates I get:
Furthermore, transparency report shows certificate installed today and lists both the main domain and the wildcard domain. Not sure why I can’t access it.
Hi @Kimofy
your certificate command has worked ( https://check-your-website.server-daten.de/?q=botivity.dev#ct-logs ):
Let’s Encrypt Authority X3 2019-08-10 2019-11-08 *.botivity.dev, botivity.dev
2 entries duplicate nr. 2
2 entries duplicate nr. 1
But certonly doesn’t install the certificate, so you have to do that manual.
Or try
certbot -d botivity.dev -d *.bitivity.dev --reinstall -i apache
Certbot should find the certificate and should try to reinstall it.
Thank you! It worked :smiley:
How would I set this up in a crontab?
I currently have:
12 8 * * * certbot renew
But as you pointed out, certbot won’t automatically install the certificate. The command you asked me to run above: certbot -d botivity.dev -d *.botivity.dev --reinstall -i apache requres user input. How can I add this into my cron job to auto install as well?
The cron command is always certbot renew.
What’s the content of your config file in
/etc/letsencrypt/renewal
This file is used when certbot renew is startet. Perhaps Certbot has already added the installer row.
    version = 0.31.0
    archive_dir = /etc/letsencrypt/archive/botivity.dev
    cert = /etc/letsencrypt/live/botivity.dev/cert.pem
    privkey = /etc/letsencrypt/live/botivity.dev/privkey.pem
    chain = /etc/letsencrypt/live/botivity.dev/chain.pem
    fullchain = /etc/letsencrypt/live/botivity.dev/fullchain.pem
    [renewalparams]
    account = [REDACTED]
    authenticator = dns-google
    dns_google_credentials = [REDACTED]
I have modified my cron command to:
12 8 * * * certbot renew && /etc/init.d/apache2 restart
Is this sufficient then?
Test it.
Check your certificate in 60 - 70 days to see, if the renew has worked. If not, you have enough time to fix it.
