Certbot not authenticating my wild card domain
My domain is: Onecoycloud.xyz
I ran this command: certbot certonly --manual --preferred-challenges=dns -d *.onecoycloud.xyz
It produced this output: Certbot failed to authenticate some domains (authenticator: manual). The Certificate Authority reported these problems:
Domain: onecoycloud.xyz
Detail: Incorrect TXT record "v=spf1 +a +mx +ip4:203.161.62.193 include:spf.web-hosting.com ~all" found at _acme-challenge.onecoycloud.xyz
Hint: The Certificate Authority failed to verify the manually created DNS TXT records. Ensure that you created these in the correct location, or try waiting longer for DNS propagation on the next attempt.
My web server is (include version): Apache2
The operating system my web server runs on is (include version): Ubuntu 19
My hosting provider, if applicable, is: Namecheap
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
That error message seems very clear. certbot would have instructed you to create a completely different TXT record; why didn't you do that?
Hi @danb35, and welcome to the LE community forum :slight_smile:
Did you follow the instructions?
Does your DSP allow for more than one TXT record?
I mean I can see why you would need that current TXT record - and you shouldn't have to remove it get a cert [using DNS-01 authentication].
I can't. That's a SPF record for _acme-challenge.onecoycloud.xyz, which would only make sense if OP were planning on having mail sent with a return address at that subdomain--which doesn't seem likely at all.
In addition to @danb35 comments about the TXT record, you probably want to add your root domain to that command. A wildcard name only covers domain names with something in place of the "*" and not the root itself.
That is, it covers www.onecoycloud.xyz or someother.onecoycloud.xyz but not onecoycloud.xyz itself
So, like this
certbot certonly --manual --preferred-challenges=dns -d onecoycloud.xyz -d *.onecoycloud.xyz
Only is a strong word...
I can think of one other way that would makes sense.
Like: To cover any and all possible [mis]uses of their domain, they would use a wildcard SPF record.
So, if anyone tries to spoof "random.sender@some.non-existing.subdomain.example.com", the wildcard SPF entry will protect from that attempt as well.
