Wildcard ssl letsencrypt from cloudflare A-record @ required?
Hello.
I generate Wildcard SSL letsencrypt from CloudFlare DNS.
In DNS I have only one record: A - * - MyIP
Can I not add an A-record A - @ - MyIP?
Will there be a check in this case?
Now I have error
Domain: ***.com
Detail: No TXT record found at _acme-challenge.***.com
Domain: ***.com
UPD: domain kinoknopka.plus
If you actually have a wildcard A record, there’s no problem. It doesn’t interfere with the creation or querying of the _acme-challenge TXT records.
However, if you create a wildcard CNAME record, then things tend to stop working, because resolvers will follow CNAMEs and ignore any TXT records under the same DNS label.
As always, the devil is in the details, so if you want help, post your real domain name.
kinoknopka.plus
please check it
That domain looks okay to me.
How are you trying to issue the wildcard certificate? What Let’s Encrypt client are you using, what command are you using, and what’s the output?
DNS: A-record - *.kinoknopka.plus - IP
Generate:
        docker run \
            --rm \
            -v "/ssl.d:/etc/letsencrypt" \
            -v "/letsencrypt:/var/lib/letsencrypt" \
            -v "/cloudflare.ini:/cloudflare.ini" \
            certbot/dns-cloudflare \
            certonly \
            --dns-cloudflare \
            --dns-cloudflare-credentials /cloudflare.ini \
            --email "support@kinoknopka.plus" \
            --non-interactive \
            --agree-tos \
            -d "kinoknopka.plus" \
            -d "*.kinoknopka.plus" \
            --server https://acme-v02.api.letsencrypt.org/directory
Result:
Domain: kinoknopka.plus
Detail: No TXT record found at _acme-challenge.kinoknopka.plus
After add DNS: A-record - kinoknopka.plus - IP
Result: Generation was successful.
Is a domain A-record kinoknopka.plus record required? *.kinoknopka.plus not enough?
If I delete the record A-record - kinoknopka.plus - IP after generation, will the certificate renewal also be an error?
