Yes it is still running!
problem begins at
2019-09-24 00:45:02 (MSK)
Wow, you werenāt kidding.
curl 7.19.7 on CentOS 6 literally hangs if you run that command.
[root@d485198a77dc /]# sh -c 'curl -L -v --dump-header /root/.acme.sh/http.header -g --user-agent "acme.sh/2.8.3 (https://github.com/Neilpang/acme.sh)" -X HEAD -H "Content-Type: application/jose+json" -H -H -H -H -H --data https://acme-v02.api.letsencrypt.org/acme/new-nonce'
* About to connect() to acme-v02.api.letsencrypt.org port 443 (#0)
* Trying 172.65.32.248... connected
* Connected to acme-v02.api.letsencrypt.org (172.65.32.248) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* SSL connection using TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
* Server certificate:
* subject: CN=acme-v01.api.letsencrypt.org
* start date: Sep 13 17:57:16 2019 GMT
* expire date: Dec 12 17:57:16 2019 GMT
* common name: acme-v01.api.letsencrypt.org
* issuer: CN=Let's Encrypt Authority X3,O=Let's Encrypt,C=US
> HEAD /acme/new-nonce HTTP/1.1
> User-Agent: acme.sh/2.8.3 (https://github.com/Neilpang/acme.sh)
> Host: acme-v02.api.letsencrypt.org
> Accept: */*
< HTTP/1.1 200 OK
< Server: nginx
< Date: Tue, 24 Sep 2019 09:06:44 GMT
< Connection: keep-alive
< Cache-Control: public, max-age=0, no-cache
< Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index"
< Replay-Nonce: 00016RUI6R2f5C6woaEjXqPQbqMw3i53QV9qxM_VhdBNBz8
< X-Frame-Options: DENY
< Strict-Transport-Security: max-age=604800
* no chunk, no close, no size. Assume close to signal end
Wait, WTF. Why is the response code HTTP 200?
HEAD is 200 and GET is 204.
So that explains it, right? curl is expecting a body because itās 200 and wasnāt told to handle it otherwise (though I guess -X HEAD should really tell it).
Certainly curl behaves differently between 7.19.7 and e.g. 7.64.0 where it works.
My curl man page says, about -X HEAD:
This option only changes the actual word used in the HTTP request, it does not alter the way curl behaves. So for example if you want to make a proper HEAD request, using -X HEAD will not suffice. You need to use the -I, --head option.
Yeah, but check out this magic trick:
[root@d485198a77dc /]# echo '104.110.202.18 acme-v02.api.letsencrypt.org' >> /etc/hosts
[root@d485198a77dc /]# curl -L -vvv --dump-header /root/.acme.sh/http.header -g --user-agent "acme.sh/2.8.3 (https://github.com/Neilpang/acme.sh)" -X HEAD -H "Content-Type: application/jose+json" -H -H -H -H -H --data https://acme-v02.api.letsencrypt.org/acme/new-nonce
* Trying 104.110.202.18... connected
* Connected to acme-v02.api.letsencrypt.org (104.110.202.18) port 443 (#0)
CApath: none
* subject: CN=acme-v02.api.letsencrypt.org
* start date: Jul 19 04:46:54 2019 GMT
* expire date: Oct 17 04:46:54 2019 GMT
* common name: acme-v02.api.letsencrypt.org
> Accept: */*
< HTTP/1.1 200 OK
< Server: nginx
< Replay-Nonce: 0102CyZ80JVdmYTcGeNtp57ksCqsaZMhxkk9TxaamltlcUY
< Content-Length: 0
< Expires: Tue, 24 Sep 2019 09:19:41 GMT
< Cache-Control: max-age=0, no-cache, no-store
< Pragma: no-cache
< Date: Tue, 24 Sep 2019 09:19:41 GMT
* Connection #0 to host acme-v02.api.letsencrypt.org left intact
* Closing connection #0
Not hung on the Akamai CDN.
@Neilpang something about the new CDN has broken your way of building HEAD request.
@lestaff too. tl;dr: curl 7.19.7 (CentOS 6) HEAD request used to work, no longer works under Cloudflare and results in a hang.
Iām guessing Akamai instantly murders the connection, and the new setup allows the client to hang on for some extremely large amount of time.
now i will try to compile fresh curl version ā¦
here https://curl.haxx.se/download.html
and give you report
Oh man. I think it's the missing Content-Length: 0 in the Cloudflare response.
When it hangs, it complains:
That makes sense. If youāre using GET semantics, a 200 OK with no Content-Length header means to wait for the responseā¦
i compile fresh curl version
[root@serv3 ~]# /opt/curl766/bin/curl -V
curl 7.66.0 (x86_64-pc-linux-gnu) libcurl/7.66.0 OpenSSL/1.0.1e-fips zlib/1.2.3
Release-Date: 2019-09-11
Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtsp smb smbs smtp smtps telnet tftp
Features: AsynchDNS HTTPS-proxy IPv6 Largefile libz NTLM NTLM_WB SSL UnixSockets
[root@serv3 ~]#
[root@serv3 ~]#
[root@serv3 ~]# /opt/curl766/bin/curl -L --include --dump-header /root/.acme.sh/http.header -g --user-agent āacme.sh/2.8.3 (https://github.com/Neilpang/acme.sh)ā -X HEAD -H āContent-Type: application/jose+jsonā https://acme-v02.api.letsencrypt.org/acme/new-nonce
Warning: Setting custom HTTP method to HEAD with -X/ārequest may not work the
Warning: way you want. Consider using -I/āhead instead.
HTTP/1.1 200 OK
Server: nginx
Date: Tue, 24 Sep 2019 09:28:08 GMT
Link: https://acme-v02.api.letsencrypt.org/directory;rel=āindexā
Replay-Nonce: 0002Wj75ACEflSW5BXSiUVR-7hG5EM35YPFNl4WLAkHMJ7Q
ā¦
waiting waiting waiting waiting waiting waiting waiting waiting waiting ā¦
^C
[root@serv3 ~]# ping acme-v02.api.letsencrypt.org
PING ca80a1adb12a4fbdac5ffcbc944e9a61.pacloudflare.com (172.65.32.248) 56(84) bytes of data.
64 bytes from 172.65.32.248: icmp_seq=1 ttl=60 time=11.4 ms
^C
ā ca80a1adb12a4fbdac5ffcbc944e9a61.pacloudflare.com ping statistics ā
1 packets transmitted, 1 received, 0% packet loss, time 553ms
rtt min/avg/max/mdev = 11.414/11.414/11.414/0.000 ms
Interesting. I wonder why it works in 7.19.7 but not the current version. (Edit: did you build with nghttp2? I think you need to build with it for the fix)
I think we probably? found the real issue. And itās one that either Letās Encrypt/Cloudflare or the author of acme.sh has to fix.
In the meantime, you can try this temporary fix:
but donāt rely on it.
[root@serv3 ~]# /opt/curl766/bin/curl -L --include --dump-header /root/.acme.sh/http.header -g --user-agent āacme.sh/2.8.3 (https://github.com/Neilpang/acme.sh)ā --head -H āContent-Type: application/jose+jsonā https://acme-v02.api.letsencrypt.org/acme/new-nonce
HTTP/1.1 200 OK
Server: nginx
Date: Tue, 24 Sep 2019 09:31:09 GMT
Replay-Nonce: 0001FgztXh2dk9XCtwKJtmauV2BqCDgDhrIs9aEUwAUhHgk
[root@serv3 ~]# curl -L --include --dump-header /root/.acme.sh/http.header -g --user-agent āacme.sh/2.8.3 (https://github.com/Neilpang/acme.sh)ā --head -H āContent-Type: application/jose+jsonā https://acme-v02.api.letsencrypt.org/acme/new-nonce
HTTP/1.1 200 OK
Server: nginx
Date: Tue, 24 Sep 2019 09:31:15 GMT
Replay-Nonce: 0002XmBsNTOtJuKJ1jEotLNX5aXuzCBW6B2_wpBgAVALHrE
[root@serv3 ~]#
with --head
work fine!
Seems to be a related acme.sh pull request open:
I have the same issue which started today:
Yesterday I issue few certificates without issue.
My curl version is 7.66.
do you really sure,
that we must to do it
where you get this IP 104.110.202.18 ?
can we trust it?
yes i build fresh curl with nghttp2 support!
Thatās just the old IP before the new CDN. If it was malicious, it wouldnāt have a valid certificate for the Letās Encrypt API domain.
But an even better fix is probably to just patch your acme.sh with the tiny fix from the PR that @mnordhoff linked.
if _post "" "$nonceurl" "" "HEAD" "$__request_conent_type"; then
if _post "" "$nonceurl" "" "HEAD --head" "$__request_conent_type"; then
(from here https://github.com/Neilpang/acme.sh/pull/2499/commits/cba97c58d5a6b93fc2ec1d415efa602332e530d1 )
right now i will try ā¦
