Wildcard sertificates dosn't issueed have timeout (acme.sh)
yes it works!
thanks to everybody!
Thanks all you guys.
I will fix it soon.
I add the patch and it works.
But it shows this error too:
“Please refer to https://curl.haxx.se/libcurl/c/libcurl-errors.html for error code: 2”
can you please show the log with --debug 2 ?
@Neilpang
https://pastebin.com/raw/ZLL79zJc
is that error produced by your from-source build of curl? Does your system curl have the same problem?
Ι use the freebsd port system to compile curl. So I didn’t manually compile it from source.
@CyberCr33p it succeed in the log , right ?
Yes I can issue/renew certificates but the curl command throughts this error:
Maybe the syntax of the curl command is not 100% correct.
please upgrade to the latest code and try again.
acme.sh  --upgrade
The same message with latest version.
what is your OS version and curl version ?
and also tell me your acme.sh version
acme.sh  --version
FreeBSD 12.0
curl 7.66.0
acme.sh v2.8.3
can you try again with --debug 2.
please upgrade and try again.
acme.sh --upgrade
Everything is ok now. Thank you very much for the help.
I will notify the freebsd port maintainer to get the latest version.
