southfield.mywire.org
The domain is a dyndns name and I am wondering if this is the issue. If I use a the same configuration in traefik labels for a name I control the DNS for and I do not have any problems.
time="2021-01-05T14:42:59Z" level=debug msg="TLS Challenge CleanUp temp certificate for southfield.mywire.org" providerName=acme
time="2021-01-05T14:42:59Z" level=debug msg="legolog: [INFO] Deactivating auth: https://acme-v02.api.letsencrypt.org/acme/authz-v3/9839901599"
time="2021-01-05T14:42:59Z" level=debug msg="legolog: [INFO] Unable to deactivate the authorization: https://acme-v02.api.letsencrypt.org/acme/authz-v3/9839901599"
time="2021-01-05T14:42:59Z" level=error msg="Unable to obtain ACME certificate for domains \"southfield.mywire.org\": unable to generate a certificate for the domains [southfield.mywire.org]: error: one or more domains had a problem:\n[southfield.mywire.org] acme: error: 400 :: urn:ietf:params:acme:error:connection :: Timeout during connect (likely firewall problem), url: \n" providerName=leresolver.acme routerName=gitlab-https@docker rule="Host(`southfield.mywire.org`)"
rails
docker
self-host
no
traefik2
