Wildcard CNAME validation problem
last two days we have a problem with validation for domain.tld + www.domain.tld when www.domain.tld is wildcard CNAME *.domain.tld CNAME domain.tld.
The error from LE is: No valid IP addresses found for …
Because we are a DNS provider, we can make a lot of checks, controlls, etc … but we didnt see any problem.
One of tests domain is expireddomains.co.za using our DNS ns to ns5.gransy.com
Domain without WWW is fully OK: https://letsdebug.net/expireddomains.co.za/132979
With WWW is failing: https://letsdebug.net/www.expireddomains.co.za/132996?debug=y
But in debug view you can see that domain is resolved to correct IP. In this case, i dont understand this error message, if you have IP address.
DNS tests is here for example:
The test is without any error.
For reducing problems with DNSSEC, this domain is not use a DNSSEC
I see two more topics here from our customers with the same problem - and of course, it is possible solve by set change CNAME to A, or create a www record directly or via DNS Validation what we used for this test domain, but the main question is what is wrong with current settings ?
  • DNS response is correct - in your debug is possible see the IP
  • DNSSEC is not active
  • DNS acme auth works correctly
  • Checks for domain without * CNAME works correctly
Thank you for check and explanation.
Jan
Edit: oh, I didn’t read properly. Sorry!
Hi @gransy
there are other topics with the same problem.
Interesting: You have deactivated DNSSEC - but you have the problem again. So it's not a DNSSEC-problem.
Perhaps that long list of name servers - expireddomains.co.za - Make your website better - DNS, redirects, mixed content, certificates - 5 nameservers (that's ok, server-daten.de has 5 name servers), but now 20 ip addresses may be part of the problem.
Checked with a local copy of unbound: (splitted):
Own domain:
unbound-host -D -v -dd www.server-daten.de.
Summary
G:\unbound>unbound-host -D -v -dd www.server-daten.de.
[1588715058] libunbound[4176:0] debug: switching log to stderr
[1588715058] libunbound[4176:0] debug: module config: "validator iterator"
[1588715058] libunbound[4176:0] notice: init module 0: validator
[1588715058] libunbound[4176:0] info: adding trusted key . DS IN
[1588715058] libunbound[4176:0] notice: init module 1: iterator
[1588715058] libunbound[4176:0] debug: target fetch policy for level 0 is 0
[1588715058] libunbound[4176:0] debug: target fetch policy for level 1 is 0
[1588715058] libunbound[4176:0] debug: target fetch policy for level 2 is 0
[1588715058] libunbound[4176:0] debug: target fetch policy for level 3 is 0
[1588715058] libunbound[4176:0] debug: target fetch policy for level 4 is 0
[1588715058] libunbound[4176:0] debug: validator[module 0] operate: extstate:module_state_initial event:module_event_new
[1588715058] libunbound[4176:0] info: validator operate: query www.server-daten.de. A IN
[1588715058] libunbound[4176:0] debug: iterator[module 1] operate: extstate:module_state_initial event:module_event_pass
[1588715058] libunbound[4176:0] info: resolving www.server-daten.de. A IN
[1588715058] libunbound[4176:0] info: priming . IN NS
[1588715058] libunbound[4176:0] info: iterator operate: query . NS IN
[1588715058] libunbound[4176:0] info: processQueryTargets: . NS IN
[1588715058] libunbound[4176:0] info: sending query: . NS IN
[1588715058] libunbound[4176:0] debug: sending to target: <.> 2001:503:c27::2:30#53
[1588715058] libunbound[4176:0] debug: iterator[module 1] operate: extstate:module_wait_reply event:module_event_reply
[1588715058] libunbound[4176:0] info: response for . NS IN
[1588715058] libunbound[4176:0] info: reply from <.> 2001:503:c27::2:30#53
[1588715058] libunbound[4176:0] info: query response was ANSWER
[1588715058] libunbound[4176:0] debug: validator[module 0] operate: extstate:module_state_initial event:module_event_moddone
[1588715058] libunbound[4176:0] info: validator operate: query . NS IN
[1588715058] libunbound[4176:0] info: priming successful for . NS IN
[1588715058] libunbound[4176:0] debug: iterator[module 1] operate: extstate:module_wait_subquery event:module_event_pass
[1588715058] libunbound[4176:0] info: iterator operate: query www.server-daten.de. A IN
[1588715058] libunbound[4176:0] info: resolving (init part 2): www.server-daten.de. A IN
[1588715058] libunbound[4176:0] info: resolving (init part 3): www.server-daten.de. A IN
[1588715058] libunbound[4176:0] info: processQueryTargets: www.server-daten.de. A IN
[1588715058] libunbound[4176:0] debug: removing 2 labels
[1588715058] libunbound[4176:0] info: sending query: de. A IN
[1588715058] libunbound[4176:0] debug: sending to target: <.> 2001:500:1::53#53
[1588715058] libunbound[4176:0] info: response for www.server-daten.de. A IN
[1588715058] libunbound[4176:0] info: reply from <.> 2001:500:1::53#53
[1588715058] libunbound[4176:0] info: query response was REFERRAL
[1588715058] libunbound[4176:0] debug: removing 1 labels
[1588715058] libunbound[4176:0] info: sending query: server-daten.de. A IN
[1588715058] libunbound[4176:0] debug: sending to target: <de.> 81.91.164.5#53
[1588715058] libunbound[4176:0] info: reply from <de.> 81.91.164.5#53
[1588715058] libunbound[4176:0] info: new target ns3.inwx.eu. AAAA IN
[1588715058] libunbound[4176:0] info: new target ns3.inwx.eu. A IN
[1588715058] libunbound[4176:0] info: iterator operate: query ns3.inwx.eu. AAAA IN
[1588715058] libunbound[4176:0] info: resolving ns3.inwx.eu. AAAA IN
[1588715058] libunbound[4176:0] info: resolving (init part 2): ns3.inwx.eu. AAAA IN
[1588715058] libunbound[4176:0] info: resolving (init part 3): ns3.inwx.eu. AAAA IN
[1588715058] libunbound[4176:0] info: processQueryTargets: ns3.inwx.eu. AAAA IN
[1588715058] libunbound[4176:0] info: sending query: eu. A IN
[1588715058] libunbound[4176:0] debug: sending to target: <.> 193.0.14.129#53
[1588715058] libunbound[4176:0] info: iterator operate: query ns3.inwx.eu. A IN
[1588715058] libunbound[4176:0] info: resolving ns3.inwx.eu. A IN
[1588715058] libunbound[4176:0] info: resolving (init part 2): ns3.inwx.eu. A IN
[1588715058] libunbound[4176:0] info: resolving (init part 3): ns3.inwx.eu. A IN
[1588715058] libunbound[4176:0] info: processQueryTargets: ns3.inwx.eu. A IN
[1588715058] libunbound[4176:0] debug: sending to target: <.> 2001:500:9f::42#53
[1588715058] libunbound[4176:0] info: response for ns3.inwx.eu. AAAA IN
[1588715058] libunbound[4176:0] info: reply from <.> 193.0.14.129#53
[1588715058] libunbound[4176:0] info: sending query: inwx.eu. A IN
[1588715058] libunbound[4176:0] debug: sending to target: <eu.> 2001:678:20::28#53
[1588715058] libunbound[4176:0] info: reply from <eu.> 2001:678:20::28#53
[1588715058] libunbound[4176:0] info: sending query: ns3.inwx.eu. A IN
[1588715058] libunbound[4176:0] debug: sending to target: <inwx.eu.> 46.165.212.97#53
[1588715058] libunbound[4176:0] info: response for ns3.inwx.eu. A IN
[1588715058] libunbound[4176:0] info: reply from <.> 2001:500:9f::42#53
[1588715058] libunbound[4176:0] debug: sending to target: <eu.> 194.146.106.90#53
[1588715058] libunbound[4176:0] info: reply from <inwx.eu.> 46.165.212.97#53
[1588715058] libunbound[4176:0] info: sending query: ns3.inwx.eu. AAAA IN
[1588715058] libunbound[4176:0] info: reply from <eu.> 194.146.106.90#53
[1588715058] libunbound[4176:0] info: query response was nodata ANSWER
[1588715058] libunbound[4176:0] info: finishing processing for ns3.inwx.eu. AAAA IN
[1588715058] libunbound[4176:0] info: validator operate: query ns3.inwx.eu. AAAA IN
[1588715058] libunbound[4176:0] info: finishing processing for ns3.inwx.eu. A IN
[1588715058] libunbound[4176:0] info: validator operate: query ns3.inwx.eu. A IN
[1588715058] libunbound[4176:0] info: sending query: www.server-daten.de. A IN
[1588715058] libunbound[4176:0] debug: sending to target: <server-daten.de.> 46.165.212.97#53
[1588715058] libunbound[4176:0] info: reply from <server-daten.de.> 46.165.212.97#53
[1588715058] libunbound[4176:0] info: finishing processing for www.server-daten.de. A IN
[1588715058] libunbound[4176:0] debug: validator[module 0] operate: extstate:module_wait_module event:module_event_moddone
[1588715058] libunbound[4176:0] info: prime trust anchor
[1588715058] libunbound[4176:0] info: generate keytag query _ta-4a5c-4f66. NULL IN
[1588715058] libunbound[4176:0] debug: validator[module 0] operate: extstate:module_state_initial event:module_event_pass
[1588715058] libunbound[4176:0] info: validator operate: query . DNSKEY IN
[1588715058] libunbound[4176:0] info: resolving . DNSKEY IN
[1588715058] libunbound[4176:0] info: resolving (init part 2): . DNSKEY IN
[1588715058] libunbound[4176:0] info: resolving (init part 3): . DNSKEY IN
[1588715058] libunbound[4176:0] info: processQueryTargets: . DNSKEY IN
[1588715058] libunbound[4176:0] info: sending query: . DNSKEY IN
[1588715058] libunbound[4176:0] debug: sending to target: <.> 2001:7fd::1#53
[1588715058] libunbound[4176:0] info: validator operate: query _ta-4a5c-4f66. NULL IN
[1588715058] libunbound[4176:0] info: resolving _ta-4a5c-4f66. NULL IN
[1588715058] libunbound[4176:0] info: resolving (init part 2): _ta-4a5c-4f66. NULL IN
[1588715058] libunbound[4176:0] info: resolving (init part 3): _ta-4a5c-4f66. NULL IN
[1588715058] libunbound[4176:0] info: processQueryTargets: _ta-4a5c-4f66. NULL IN
[1588715058] libunbound[4176:0] info: sending query: _ta-4a5c-4f66. A IN
[1588715058] libunbound[4176:0] debug: sending to target: <.> 2001:500:12::d0d#53
[1588715058] libunbound[4176:0] info: iterator operate: query . DNSKEY IN
[1588715058] libunbound[4176:0] info: response for . DNSKEY IN
[1588715058] libunbound[4176:0] info: reply from <.> 2001:7fd::1#53
[1588715058] libunbound[4176:0] info: finishing processing for . DNSKEY IN
[1588715058] libunbound[4176:0] info: validate keys with anchor(DS): sec_status_secure
[1588715058] libunbound[4176:0] info: Successfully primed trust anchor . DNSKEY IN
[1588715058] libunbound[4176:0] debug: validator[module 0] operate: extstate:module_wait_subquery event:module_event_pass
[1588715058] libunbound[4176:0] info: validated DS de. DS IN
[1588715058] libunbound[4176:0] info: validator operate: query de. DNSKEY IN
[1588715058] libunbound[4176:0] info: resolving de. DNSKEY IN
[1588715058] libunbound[4176:0] info: resolving (init part 2): de. DNSKEY IN
[1588715058] libunbound[4176:0] info: resolving (init part 3): de. DNSKEY IN
[1588715058] libunbound[4176:0] info: processQueryTargets: de. DNSKEY IN
[1588715058] libunbound[4176:0] info: sending query: de. DNSKEY IN
[1588715058] libunbound[4176:0] debug: sending to target: <de.> 2001:668:1f:11::105#53
[1588715058] libunbound[4176:0] info: iterator operate: query _ta-4a5c-4f66. NULL IN
[1588715058] libunbound[4176:0] info: response for _ta-4a5c-4f66. NULL IN
[1588715058] libunbound[4176:0] info: reply from <.> 2001:500:12::d0d#53
[1588715058] libunbound[4176:0] info: query response was NXDOMAIN ANSWER
[1588715058] libunbound[4176:0] info: finishing processing for _ta-4a5c-4f66. NULL IN
[1588715058] libunbound[4176:0] info: iterator operate: query de. DNSKEY IN
[1588715058] libunbound[4176:0] info: response for de. DNSKEY IN
[1588715058] libunbound[4176:0] info: reply from <de.> 2001:668:1f:11::105#53
[1588715058] libunbound[4176:0] info: finishing processing for de. DNSKEY IN
[1588715058] libunbound[4176:0] info: validated DNSKEY de. DNSKEY IN
[1588715058] libunbound[4176:0] info: validated DS server-daten.de. DS IN
[1588715058] libunbound[4176:0] info: validator operate: query server-daten.de. DNSKEY IN
[1588715058] libunbound[4176:0] info: resolving server-daten.de. DNSKEY IN
[1588715058] libunbound[4176:0] info: resolving (init part 2): server-daten.de. DNSKEY IN
[1588715058] libunbound[4176:0] info: resolving (init part 3): server-daten.de. DNSKEY IN
[1588715058] libunbound[4176:0] info: processQueryTargets: server-daten.de. DNSKEY IN
[1588715058] libunbound[4176:0] info: sending query: server-daten.de. DNSKEY IN
[1588715058] libunbound[4176:0] info: iterator operate: query server-daten.de. DNSKEY IN
[1588715058] libunbound[4176:0] info: response for server-daten.de. DNSKEY IN
[1588715058] libunbound[4176:0] info: finishing processing for server-daten.de. DNSKEY IN
[1588715058] libunbound[4176:0] info: validated DNSKEY server-daten.de. DNSKEY IN
[1588715058] libunbound[4176:0] info: validate(positive): sec_status_secure
[1588715058] libunbound[4176:0] info: validation success www.server-daten.de. A IN
www.server-daten.de. has address 85.215.2.226 (secure)
[1588715058] libunbound[4176:0] info: validator operate: query www.server-daten.de. AAAA IN
[1588715058] libunbound[4176:0] info: resolving www.server-daten.de. AAAA IN
[1588715058] libunbound[4176:0] info: resolving (init part 2): www.server-daten.de. AAAA IN
[1588715058] libunbound[4176:0] info: resolving (init part 3): www.server-daten.de. AAAA IN
[1588715058] libunbound[4176:0] info: processQueryTargets: www.server-daten.de. AAAA IN
[1588715058] libunbound[4176:0] info: iterator operate: query www.server-daten.de. AAAA IN
[1588715058] libunbound[4176:0] info: response for www.server-daten.de. AAAA IN
[1588715058] libunbound[4176:0] info: sending query: www.server-daten.de. AAAA IN
[1588715058] libunbound[4176:0] info: finishing processing for www.server-daten.de. AAAA IN
[1588715058] libunbound[4176:0] info: validation success www.server-daten.de. AAAA IN
www.server-daten.de. has IPv6 address 2a01:238:301b::1226 (secure)
[1588715058] libunbound[4176:0] info: validator operate: query www.server-daten.de. MX IN
[1588715058] libunbound[4176:0] info: resolving www.server-daten.de. MX IN
[1588715058] libunbound[4176:0] info: resolving (init part 2): www.server-daten.de. MX IN
[1588715058] libunbound[4176:0] info: resolving (init part 3): www.server-daten.de. MX IN
[1588715058] libunbound[4176:0] info: processQueryTargets: www.server-daten.de. MX IN
[1588715058] libunbound[4176:0] info: iterator operate: query www.server-daten.de. MX IN
[1588715058] libunbound[4176:0] info: response for www.server-daten.de. MX IN
[1588715058] libunbound[4176:0] info: sending query: www.server-daten.de. MX IN
[1588715058] libunbound[4176:0] info: finishing processing for www.server-daten.de. MX IN
[1588715058] libunbound[4176:0] info: validate(nodata): sec_status_secure
[1588715058] libunbound[4176:0] info: validation success www.server-daten.de. MX IN
www.server-daten.de. has no mail handler record (secure)
Your www domain (first part):
G:\unbound>unbound-host -D -v -dd www.expireddomains.co.za.
Summary
[1588715268] libunbound[22404:0] debug: switching log to stderr
[1588715268] libunbound[22404:0] debug: module config: "validator iterator"
[1588715268] libunbound[22404:0] notice: init module 0: validator
[1588715268] libunbound[22404:0] info: adding trusted key . DS IN
[1588715268] libunbound[22404:0] notice: init module 1: iterator
[1588715268] libunbound[22404:0] debug: target fetch policy for level 0 is 0
[1588715268] libunbound[22404:0] debug: target fetch policy for level 1 is 0
[1588715268] libunbound[22404:0] debug: target fetch policy for level 2 is 0
[1588715268] libunbound[22404:0] debug: target fetch policy for level 3 is 0
[1588715268] libunbound[22404:0] debug: target fetch policy for level 4 is 0
[1588715269] libunbound[22404:0] debug: validator[module 0] operate: extstate:module_state_initial event:module_event_new
[1588715269] libunbound[22404:0] info: validator operate: query www.expireddomains.co.za. A IN
[1588715269] libunbound[22404:0] debug: iterator[module 1] operate: extstate:module_state_initial event:module_event_pass
[1588715269] libunbound[22404:0] info: resolving www.expireddomains.co.za. A IN
[1588715269] libunbound[22404:0] info: priming . IN NS
[1588715269] libunbound[22404:0] info: iterator operate: query . NS IN
[1588715269] libunbound[22404:0] info: processQueryTargets: . NS IN
[1588715269] libunbound[22404:0] info: sending query: . NS IN
[1588715269] libunbound[22404:0] debug: sending to target: <.> 2001:503:c27::2:30#53
[1588715269] libunbound[22404:0] debug: iterator[module 1] operate: extstate:module_wait_reply event:module_event_reply
[1588715269] libunbound[22404:0] info: response for . NS IN
[1588715269] libunbound[22404:0] info: reply from <.> 2001:503:c27::2:30#53
[1588715269] libunbound[22404:0] info: query response was ANSWER
[1588715269] libunbound[22404:0] debug: validator[module 0] operate: extstate:module_state_initial event:module_event_moddone
[1588715269] libunbound[22404:0] info: validator operate: query . NS IN
[1588715269] libunbound[22404:0] info: priming successful for . NS IN
[1588715269] libunbound[22404:0] debug: iterator[module 1] operate: extstate:module_wait_subquery event:module_event_pass
[1588715269] libunbound[22404:0] info: iterator operate: query www.expireddomains.co.za. A IN
[1588715269] libunbound[22404:0] info: resolving (init part 2): www.expireddomains.co.za. A IN
[1588715269] libunbound[22404:0] info: resolving (init part 3): www.expireddomains.co.za. A IN
[1588715269] libunbound[22404:0] info: processQueryTargets: www.expireddomains.co.za. A IN
[1588715269] libunbound[22404:0] debug: removing 3 labels
[1588715269] libunbound[22404:0] info: sending query: za. A IN
[1588715269] libunbound[22404:0] debug: sending to target: <.> 198.41.0.4#53
[1588715269] libunbound[22404:0] info: response for www.expireddomains.co.za. A IN
[1588715269] libunbound[22404:0] info: reply from <.> 198.41.0.4#53
[1588715269] libunbound[22404:0] info: query response was REFERRAL
[1588715269] libunbound[22404:0] debug: removing 2 labels
[1588715269] libunbound[22404:0] info: sending query: co.za. A IN
[1588715269] libunbound[22404:0] debug: sending to target: <za.> 2001:500:14:6055:ad::1#53
[1588715269] libunbound[22404:0] info: reply from <za.> 2001:500:14:6055:ad::1#53
[1588715269] libunbound[22404:0] debug: removing 1 labels
[1588715269] libunbound[22404:0] info: sending query: expireddomains.co.za. A IN
[1588715269] libunbound[22404:0] debug: sending to target: <co.za.> 196.4.160.17#53
[1588715269] libunbound[22404:0] info: reply from <co.za.> 196.4.160.17#53
[1588715269] libunbound[22404:0] info: new target ns3.gransy.com. AAAA IN
[1588715269] libunbound[22404:0] info: new target ns3.gransy.com. A IN
[1588715269] libunbound[22404:0] info: iterator operate: query ns3.gransy.com. AAAA IN
[1588715269] libunbound[22404:0] info: resolving ns3.gransy.com. AAAA IN
[1588715269] libunbound[22404:0] info: resolving (init part 2): ns3.gransy.com. AAAA IN
[1588715269] libunbound[22404:0] info: resolving (init part 3): ns3.gransy.com. AAAA IN
[1588715269] libunbound[22404:0] info: processQueryTargets: ns3.gransy.com. AAAA IN
[1588715269] libunbound[22404:0] info: sending query: com. A IN
[1588715269] libunbound[22404:0] debug: sending to target: <.> 192.203.230.10#53
[1588715269] libunbound[22404:0] info: iterator operate: query ns3.gransy.com. A IN
[1588715269] libunbound[22404:0] info: resolving ns3.gransy.com. A IN
[1588715269] libunbound[22404:0] info: resolving (init part 2): ns3.gransy.com. A IN
[1588715269] libunbound[22404:0] info: resolving (init part 3): ns3.gransy.com. A IN
[1588715269] libunbound[22404:0] info: processQueryTargets: ns3.gransy.com. A IN
[1588715269] libunbound[22404:0] debug: sending to target: <.> 2001:500:9f::42#53
[1588715269] libunbound[22404:0] info: response for ns3.gransy.com. AAAA IN
[1588715269] libunbound[22404:0] info: reply from <.> 192.203.230.10#53
[1588715269] libunbound[22404:0] info: sending query: gransy.com. A IN
[1588715269] libunbound[22404:0] debug: sending to target: <com.> 192.31.80.30#53
[1588715269] libunbound[22404:0] info: response for ns3.gransy.com. A IN
[1588715269] libunbound[22404:0] info: reply from <.> 2001:500:9f::42#53
[1588715269] libunbound[22404:0] debug: sending to target: <com.> 2001:500:856e::30#53
[1588715269] libunbound[22404:0] info: reply from <com.> 2001:500:856e::30#53
[1588715269] libunbound[22404:0] info: new target ns1.anycastdns.cz. AAAA IN
[1588715269] libunbound[22404:0] info: new target ns1.anycastdns.cz. A IN
[1588715269] libunbound[22404:0] info: iterator operate: query ns1.anycastdns.cz. AAAA IN
[1588715269] libunbound[22404:0] info: resolving ns1.anycastdns.cz. AAAA IN
[1588715269] libunbound[22404:0] info: resolving (init part 2): ns1.anycastdns.cz. AAAA IN
[1588715269] libunbound[22404:0] info: resolving (init part 3): ns1.anycastdns.cz. AAAA IN
[1588715269] libunbound[22404:0] info: processQueryTargets: ns1.anycastdns.cz. AAAA IN
[1588715269] libunbound[22404:0] info: sending query: cz. A IN
[1588715269] libunbound[22404:0] info: iterator operate: query ns1.anycastdns.cz. A IN
[1588715269] libunbound[22404:0] info: resolving ns1.anycastdns.cz. A IN
[1588715269] libunbound[22404:0] info: resolving (init part 2): ns1.anycastdns.cz. A IN
[1588715269] libunbound[22404:0] info: resolving (init part 3): ns1.anycastdns.cz. A IN
[1588715269] libunbound[22404:0] info: processQueryTargets: ns1.anycastdns.cz. A IN
[1588715269] libunbound[22404:0] debug: sending to target: <.> 193.0.14.129#53
[1588715269] libunbound[22404:0] info: response for ns1.anycastdns.cz. A IN
[1588715269] libunbound[22404:0] info: reply from <.> 193.0.14.129#53
[1588715269] libunbound[22404:0] info: sending query: anycastdns.cz. A IN
[1588715269] libunbound[22404:0] debug: sending to target: <cz.> 2001:678:1::1#53
[1588715269] libunbound[22404:0] info: response for ns1.anycastdns.cz. AAAA IN
[1588715269] libunbound[22404:0] debug: sending to target: <cz.> 194.0.12.1#53
[1588715269] libunbound[22404:0] info: reply from <com.> 192.31.80.30#53
[1588715269] libunbound[22404:0] info: reply from <cz.> 2001:678:1::1#53
[1588715269] libunbound[22404:0] info: sending query: ns1.anycastdns.cz. A IN
[1588715269] libunbound[22404:0] debug: sending to target: <anycastdns.cz.> 66.42.94.136#53
[1588715269] libunbound[22404:0] info: reply from <cz.> 194.0.12.1#53
[1588715269] libunbound[22404:0] debug: sending to target: <anycastdns.cz.> 45.76.90.43#53
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns.gransy.cz. A IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns.gransy.cz. AAAA IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns2.gransy.cz. A IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns2.gransy.cz. AAAA IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns3.gransy.cz. A IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns3.gransy.cz. AAAA IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns4.gransy.cz. A IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns4.gransy.cz. AAAA IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns5.gransy.cz. A IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns5.gransy.cz. AAAA IN
[1588715269] libunbound[22404:0] info: reply from <anycastdns.cz.> 45.76.90.43#53
[1588715269] libunbound[22404:0] info: sending query: ns1.anycastdns.cz. AAAA IN
[1588715269] libunbound[22404:0] debug: sending to target: <anycastdns.cz.> 2001:19f0:6801:474:5400:1ff:fec5:8efb#53
[1588715269] libunbound[22404:0] info: reply from <anycastdns.cz.> 2001:19f0:6801:474:5400:1ff:fec5:8efb#53
[1588715269] libunbound[22404:0] info: query response was nodata ANSWER
[1588715269] libunbound[22404:0] info: finishing processing for ns1.anycastdns.cz. AAAA IN
[1588715269] libunbound[22404:0] info: validator operate: query ns1.anycastdns.cz. AAAA IN
[1588715269] libunbound[22404:0] info: reply from <anycastdns.cz.> 66.42.94.136#53
[1588715269] libunbound[22404:0] info: finishing processing for ns1.anycastdns.cz. A IN
[1588715269] libunbound[22404:0] info: validator operate: query ns1.anycastdns.cz. A IN
[1588715269] libunbound[22404:0] info: sending query: ns3.gransy.com. A IN
[1588715269] libunbound[22404:0] debug: sending to target: <gransy.com.> 185.38.108.108#53
[1588715269] libunbound[22404:0] info: reply from <gransy.com.> 185.38.108.108#53
[1588715269] libunbound[22404:0] info: sending query: ns3.gransy.com. AAAA IN
[1588715269] libunbound[22404:0] info: finishing processing for ns3.gransy.com. A IN
[1588715269] libunbound[22404:0] info: validator operate: query ns3.gransy.com. A IN
[1588715269] libunbound[22404:0] info: sending query: www.expireddomains.co.za. A IN
[1588715269] libunbound[22404:0] debug: sending to target: <expireddomains.co.za.> 77.78.126.35#53
[1588715269] libunbound[22404:0] info: finishing processing for ns3.gransy.com. AAAA IN
[1588715269] libunbound[22404:0] info: validator operate: query ns3.gransy.com. AAAA IN
[1588715269] libunbound[22404:0] debug: iterator[module 1] operate: extstate:module_wait_reply event:module_event_pass
[1588715269] libunbound[22404:0] info: sanitize: removing extraneous answer RRset: expireddomains.co.za. A IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns.gransy.com. A IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns2.gransy.com. A IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns3.gransy.com. A IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns4.gransy.com. A IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns5.gransy.com. A IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns.gransy.com. AAAA IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns2.gransy.com. AAAA IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns3.gransy.com. AAAA IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns4.gransy.com. AAAA IN
[1588715269] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns5.gransy.com. AAAA IN
Second part:
Summary
[1588715269] libunbound[22404:0] info: reply from <expireddomains.co.za.> 77.78.126.35#53
[1588715269] libunbound[22404:0] info: query response was CNAME
[1588715269] libunbound[22404:0] debug: sending to target: <expireddomains.co.za.> 2a02:750:7::2e7#53
[1588715270] libunbound[22404:0] debug: iterator[module 1] operate: extstate:module_wait_reply event:module_event_reply
[1588715270] libunbound[22404:0] info: iterator operate: query www.expireddomains.co.za. A IN
[1588715270] libunbound[22404:0] info: iterator operate: chased to expireddomains.co.za. A IN
[1588715270] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns.gransy.com. A IN
[1588715270] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns2.gransy.com. A IN
[1588715270] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns3.gransy.com. A IN
[1588715270] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns4.gransy.com. A IN
[1588715270] libunbound[22404:0] info: response for www.expireddomains.co.za. A IN
[1588715270] libunbound[22404:0] info: reply from <expireddomains.co.za.> 2a02:750:7::2e7#53
[1588715270] libunbound[22404:0] info: query response was ANSWER
[1588715270] libunbound[22404:0] info: finishing processing for www.expireddomains.co.za. A IN
[1588715270] libunbound[22404:0] debug: validator[module 0] operate: extstate:module_wait_module event:module_event_moddone
[1588715270] libunbound[22404:0] info: validator operate: query www.expireddomains.co.za. A IN
[1588715270] libunbound[22404:0] info: prime trust anchor
[1588715270] libunbound[22404:0] info: generate keytag query _ta-4a5c-4f66. NULL IN
[1588715270] libunbound[22404:0] debug: validator[module 0] operate: extstate:module_state_initial event:module_event_pass
[1588715270] libunbound[22404:0] info: validator operate: query . DNSKEY IN
[1588715270] libunbound[22404:0] debug: iterator[module 1] operate: extstate:module_state_initial event:module_event_pass
[1588715270] libunbound[22404:0] info: resolving . DNSKEY IN
[1588715270] libunbound[22404:0] info: resolving (init part 2): . DNSKEY IN
[1588715270] libunbound[22404:0] info: resolving (init part 3): . DNSKEY IN
[1588715270] libunbound[22404:0] info: processQueryTargets: . DNSKEY IN
[1588715270] libunbound[22404:0] info: sending query: . DNSKEY IN
[1588715270] libunbound[22404:0] debug: sending to target: <.> 2001:500:a8::e#53
[1588715270] libunbound[22404:0] info: validator operate: query _ta-4a5c-4f66. NULL IN
[1588715270] libunbound[22404:0] info: resolving _ta-4a5c-4f66. NULL IN
[1588715270] libunbound[22404:0] info: resolving (init part 2): _ta-4a5c-4f66. NULL IN
[1588715270] libunbound[22404:0] info: resolving (init part 3): _ta-4a5c-4f66. NULL IN
[1588715270] libunbound[22404:0] info: processQueryTargets: _ta-4a5c-4f66. NULL IN
[1588715270] libunbound[22404:0] info: sending query: _ta-4a5c-4f66. A IN
[1588715270] libunbound[22404:0] debug: sending to target: <.> 198.97.190.53#53
[1588715270] libunbound[22404:0] info: iterator operate: query . DNSKEY IN
[1588715270] libunbound[22404:0] info: response for . DNSKEY IN
[1588715270] libunbound[22404:0] info: reply from <.> 2001:500:a8::e#53
[1588715270] libunbound[22404:0] info: finishing processing for . DNSKEY IN
[1588715270] libunbound[22404:0] info: validate keys with anchor(DS): sec_status_secure
[1588715270] libunbound[22404:0] info: Successfully primed trust anchor . DNSKEY IN
[1588715270] libunbound[22404:0] debug: validator[module 0] operate: extstate:module_wait_subquery event:module_event_pass
[1588715270] libunbound[22404:0] info: validated DS za. DS IN
[1588715270] libunbound[22404:0] info: validator operate: query za. DNSKEY IN
[1588715270] libunbound[22404:0] info: resolving za. DNSKEY IN
[1588715270] libunbound[22404:0] info: resolving (init part 2): za. DNSKEY IN
[1588715270] libunbound[22404:0] info: resolving (init part 3): za. DNSKEY IN
[1588715270] libunbound[22404:0] info: processQueryTargets: za. DNSKEY IN
[1588715270] libunbound[22404:0] info: sending query: za. DNSKEY IN
[1588715270] libunbound[22404:0] debug: sending to target: <za.> 194.146.106.78#53
[1588715270] libunbound[22404:0] info: iterator operate: query za. DNSKEY IN
[1588715270] libunbound[22404:0] info: response for za. DNSKEY IN
[1588715270] libunbound[22404:0] info: reply from <za.> 194.146.106.78#53
[1588715270] libunbound[22404:0] info: finishing processing for za. DNSKEY IN
[1588715270] libunbound[22404:0] info: validated DNSKEY za. DNSKEY IN
[1588715270] libunbound[22404:0] info: validated DS co.za. DS IN
[1588715270] libunbound[22404:0] info: validator operate: query co.za. DNSKEY IN
[1588715270] libunbound[22404:0] info: resolving co.za. DNSKEY IN
[1588715270] libunbound[22404:0] info: resolving (init part 2): co.za. DNSKEY IN
[1588715270] libunbound[22404:0] info: resolving (init part 3): co.za. DNSKEY IN
[1588715270] libunbound[22404:0] info: processQueryTargets: co.za. DNSKEY IN
[1588715270] libunbound[22404:0] info: sending query: co.za. DNSKEY IN
[1588715270] libunbound[22404:0] debug: sending to target: <co.za.> 196.4.160.17#53
[1588715270] libunbound[22404:0] info: iterator operate: query _ta-4a5c-4f66. NULL IN
[1588715270] libunbound[22404:0] info: response for _ta-4a5c-4f66. NULL IN
[1588715270] libunbound[22404:0] info: reply from <.> 198.97.190.53#53
[1588715270] libunbound[22404:0] info: query response was NXDOMAIN ANSWER
[1588715270] libunbound[22404:0] info: finishing processing for _ta-4a5c-4f66. NULL IN
[1588715270] libunbound[22404:0] info: iterator operate: query co.za. DNSKEY IN
[1588715270] libunbound[22404:0] info: response for co.za. DNSKEY IN
[1588715270] libunbound[22404:0] info: reply from <co.za.> 196.4.160.17#53
[1588715270] libunbound[22404:0] info: finishing processing for co.za. DNSKEY IN
[1588715270] libunbound[22404:0] info: validated DNSKEY co.za. DNSKEY IN
[1588715270] libunbound[22404:0] info: NSEC3s for the referral proved no DS.
[1588715270] libunbound[22404:0] info: Verified that response is INSECURE
www.expireddomains.co.za. is an alias for expireddomains.co.za. (insecure)
expireddomains.co.za has address 185.82.212.80 (insecure)
[1588715270] libunbound[22404:0] debug: validator[module 0] operate: extstate:module_state_initial event:module_event_new
[1588715270] libunbound[22404:0] info: validator operate: query www.expireddomains.co.za. AAAA IN
[1588715270] libunbound[22404:0] info: resolving www.expireddomains.co.za. AAAA IN
[1588715270] libunbound[22404:0] info: resolving (init part 2): www.expireddomains.co.za. AAAA IN
[1588715270] libunbound[22404:0] info: resolving (init part 3): www.expireddomains.co.za. AAAA IN
[1588715270] libunbound[22404:0] info: processQueryTargets: www.expireddomains.co.za. AAAA IN
[1588715270] libunbound[22404:0] info: sending query: www.expireddomains.co.za. A IN
[1588715270] libunbound[22404:0] debug: sending to target: <expireddomains.co.za.> 46.21.100.103#53
[1588715270] libunbound[22404:0] info: iterator operate: query www.expireddomains.co.za. AAAA IN
[1588715270] libunbound[22404:0] info: sanitize: removing extraneous answer RRset: expireddomains.co.za. A IN
[1588715270] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns5.gransy.com. A IN
[1588715270] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns.gransy.com. AAAA IN
[1588715270] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns2.gransy.com. AAAA IN
[1588715270] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns3.gransy.com. AAAA IN
[1588715270] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns4.gransy.com. AAAA IN
[1588715270] libunbound[22404:0] info: sanitize: removing potential poison RRset: ns5.gransy.com. AAAA IN
[1588715270] libunbound[22404:0] info: response for www.expireddomains.co.za. AAAA IN
[1588715270] libunbound[22404:0] info: reply from <expireddomains.co.za.> 46.21.100.103#53
[1588715270] libunbound[22404:0] info: query response was CNAME
[1588715270] libunbound[22404:0] info: sending query: expireddomains.co.za. AAAA IN
[1588715270] libunbound[22404:0] debug: sending to target: <expireddomains.co.za.> 77.78.126.35#53
[1588715270] libunbound[22404:0] info: iterator operate: chased to expireddomains.co.za. AAAA IN
[1588715270] libunbound[22404:0] info: reply from <expireddomains.co.za.> 77.78.126.35#53
[1588715270] libunbound[22404:0] info: query response was nodata ANSWER
[1588715270] libunbound[22404:0] info: finishing processing for www.expireddomains.co.za. AAAA IN
expireddomains.co.za has no IPv6 address (insecure)
[1588715270] libunbound[22404:0] info: validator operate: query www.expireddomains.co.za. MX IN
[1588715270] libunbound[22404:0] info: resolving www.expireddomains.co.za. MX IN
[1588715270] libunbound[22404:0] info: resolving (init part 2): www.expireddomains.co.za. MX IN
[1588715270] libunbound[22404:0] info: resolving (init part 3): www.expireddomains.co.za. MX IN
[1588715270] libunbound[22404:0] info: processQueryTargets: www.expireddomains.co.za. MX IN
[1588715270] libunbound[22404:0] debug: sending to target: <expireddomains.co.za.> 2a02:750:7::2e7#53
[1588715270] libunbound[22404:0] info: iterator operate: query www.expireddomains.co.za. MX IN
[1588715270] libunbound[22404:0] info: response for www.expireddomains.co.za. MX IN
[1588715270] libunbound[22404:0] info: sending query: expireddomains.co.za. MX IN
[1588715270] libunbound[22404:0] debug: sending to target: <expireddomains.co.za.> 109.74.7.71#53
[1588715270] libunbound[22404:0] info: iterator operate: chased to expireddomains.co.za. MX IN
[1588715270] libunbound[22404:0] info: reply from <expireddomains.co.za.> 109.74.7.71#53
[1588715270] libunbound[22404:0] info: finishing processing for www.expireddomains.co.za. MX IN
expireddomains.co.za mail is handled by 10 mail.expireddomains.co.za. (insecure)
There are a lot of
checking the list of name servers
Thank you … i will try remove AUTHORITY and ADDITIONAL sections from every responses. It will help for decrease a size of response and we will see if the problem will solved or not.
No, I don't think that's the problem.
Your configuration is buggy.
expireddomains.co.za -> NS -> ns3.gransy.com.
ns3.gransy.com -> NS -> ns1.anycastdns.cz.
And
D:\temp>nslookup -type=NS anycastdns.cz.
anycastdns.cz nameserver = ns5.gransy.cz
anycastdns.cz nameserver = ns2.gransy.cz
anycastdns.cz nameserver = ns4.gransy.cz
anycastdns.cz nameserver = ns3.gransy.cz
anycastdns.cz nameserver = ns.gransy.cz
That's a name server loop, there are no glue records.
And ns.gransy.cz -> SOA ns.gransy.com.
Same with dig:
:~$ dig NS ns.gransy.com.
; <<>> DiG 9.11.3-1ubuntu1.11-Ubuntu <<>> NS ns.gransy.com.
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 38707
;; flags: qr rd ra ad; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;ns.gransy.com. IN NS
;; AUTHORITY SECTION:
gransy.com. 1132 IN SOA ns1.anycastdns.cz. root.gransy.com. 2588707815 86400 900 1209600 1800
;; Query time: 0 msec
;; SERVER: 192.168.0.1#53(192.168.0.1)
;; WHEN: Wed May 06 00:31:32 CEST 2020
;; MSG SIZE rcvd: 100
:~$ dig NS anycastdns.cz.
; <<>> DiG 9.11.3-1ubuntu1.11-Ubuntu <<>> NS anycastdns.cz.
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 60502
;; flags: qr rd ra ad; QUERY: 1, ANSWER: 5, AUTHORITY: 0, ADDITIONAL: 1
;anycastdns.cz. IN NS
;; ANSWER SECTION:
anycastdns.cz. 1511 IN NS ns3.gransy.cz.
anycastdns.cz. 1511 IN NS ns2.gransy.cz.
anycastdns.cz. 1511 IN NS ns5.gransy.cz.
anycastdns.cz. 1511 IN NS ns4.gransy.cz.
anycastdns.cz. 1511 IN NS ns.gransy.cz.
;; WHEN: Wed May 06 00:35:52 CEST 2020
;; MSG SIZE rcvd: 138
:~$ dig NS ns3.gransy.cz.
; <<>> DiG 9.11.3-1ubuntu1.11-Ubuntu <<>> NS ns3.gransy.cz.
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 6261
;ns3.gransy.cz. IN NS
gransy.cz. 1800 IN SOA ns.gransy.com. root.gransy.com. 2588707810 86400 900 1209600 1800
;; Query time: 178 msec
;; WHEN: Wed May 06 00:36:04 CEST 2020
;; MSG SIZE rcvd: 96
:~$ dig NS ns3.gransy.com.
; <<>> DiG 9.11.3-1ubuntu1.11-Ubuntu <<>> NS ns3.gransy.com.
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 57872
;ns3.gransy.com. IN NS
gransy.com. 714 IN SOA ns1.anycastdns.cz. root.gransy.com. 2588707815 86400 900 1209600 1800
;; WHEN: Wed May 06 00:36:22 CEST 2020
;; MSG SIZE rcvd: 101
One domain -> next domain -> next domain -> first domain.
Query NS, answer SOA.
So it's unclear how to find the ip addresses of your name servers.
I set minimal-responses: yes; in our backends Bind DNS for disabling Authority and Additional sections for question where is no needed and all tests here looks fine for everything. (Your last post was after update, for this reasson you didnt see the long authority lists as before)
Certificates what was failng today is now generated successfully! Problem solved!
Thanks for your help!
And about delegation:
I see that Verisign don’t propage a glue records in case when domain use another DNS :-/ For this reasson there is only gransy.cz with glue records on TLD zone. I will check and solve later, but now everything looks works.
EDIT: and finally set gransy.com to ns/ns5.gransy.com for generate a Glue records in .COM zone. From this time i dont see any errors in unbountest.
Jan
Yep, now the log is reduced. From 42K to 29K.
Summary
[1588720847] libunbound[11360:0] debug: switching log to stderr
[1588720847] libunbound[11360:0] debug: module config: "validator iterator"
[1588720847] libunbound[11360:0] notice: init module 0: validator
[1588720847] libunbound[11360:0] info: adding trusted key . DS IN
[1588720847] libunbound[11360:0] notice: init module 1: iterator
[1588720847] libunbound[11360:0] debug: target fetch policy for level 0 is 0
[1588720847] libunbound[11360:0] debug: target fetch policy for level 1 is 0
[1588720847] libunbound[11360:0] debug: target fetch policy for level 2 is 0
[1588720847] libunbound[11360:0] debug: target fetch policy for level 3 is 0
[1588720847] libunbound[11360:0] debug: target fetch policy for level 4 is 0
[1588720847] libunbound[11360:0] debug: validator[module 0] operate: extstate:module_state_initial event:module_event_new
[1588720847] libunbound[11360:0] info: validator operate: query www.expireddomains.co.za. A IN
[1588720847] libunbound[11360:0] debug: iterator[module 1] operate: extstate:module_state_initial event:module_event_pass
[1588720847] libunbound[11360:0] info: resolving www.expireddomains.co.za. A IN
[1588720847] libunbound[11360:0] info: priming . IN NS
[1588720847] libunbound[11360:0] info: iterator operate: query . NS IN
[1588720847] libunbound[11360:0] info: processQueryTargets: . NS IN
[1588720847] libunbound[11360:0] info: sending query: . NS IN
[1588720847] libunbound[11360:0] debug: sending to target: <.> 199.7.83.42#53
[1588720847] libunbound[11360:0] debug: iterator[module 1] operate: extstate:module_wait_reply event:module_event_reply
[1588720847] libunbound[11360:0] info: response for . NS IN
[1588720847] libunbound[11360:0] info: reply from <.> 199.7.83.42#53
[1588720847] libunbound[11360:0] info: query response was ANSWER
[1588720847] libunbound[11360:0] debug: validator[module 0] operate: extstate:module_state_initial event:module_event_moddone
[1588720847] libunbound[11360:0] info: validator operate: query . NS IN
[1588720847] libunbound[11360:0] info: priming successful for . NS IN
[1588720847] libunbound[11360:0] debug: iterator[module 1] operate: extstate:module_wait_subquery event:module_event_pass
[1588720847] libunbound[11360:0] info: iterator operate: query www.expireddomains.co.za. A IN
[1588720847] libunbound[11360:0] info: resolving (init part 2): www.expireddomains.co.za. A IN
[1588720847] libunbound[11360:0] info: resolving (init part 3): www.expireddomains.co.za. A IN
[1588720847] libunbound[11360:0] info: processQueryTargets: www.expireddomains.co.za. A IN
[1588720847] libunbound[11360:0] debug: removing 3 labels
[1588720847] libunbound[11360:0] info: sending query: za. A IN
[1588720847] libunbound[11360:0] debug: sending to target: <.> 192.33.4.12#53
[1588720847] libunbound[11360:0] info: response for www.expireddomains.co.za. A IN
[1588720847] libunbound[11360:0] info: reply from <.> 192.33.4.12#53
[1588720847] libunbound[11360:0] info: query response was REFERRAL
[1588720847] libunbound[11360:0] debug: removing 2 labels
[1588720847] libunbound[11360:0] info: sending query: co.za. A IN
[1588720847] libunbound[11360:0] debug: sending to target: <za.> 196.4.160.27#53
[1588720847] libunbound[11360:0] info: reply from <za.> 196.4.160.27#53
[1588720847] libunbound[11360:0] debug: removing 1 labels
[1588720847] libunbound[11360:0] info: sending query: expireddomains.co.za. A IN
[1588720847] libunbound[11360:0] debug: sending to target: <co.za.> 196.4.160.17#53
[1588720847] libunbound[11360:0] info: reply from <co.za.> 196.4.160.17#53
[1588720847] libunbound[11360:0] info: new target ns5.gransy.com. AAAA IN
[1588720847] libunbound[11360:0] info: new target ns5.gransy.com. A IN
[1588720847] libunbound[11360:0] info: iterator operate: query ns5.gransy.com. AAAA IN
[1588720847] libunbound[11360:0] info: resolving ns5.gransy.com. AAAA IN
[1588720847] libunbound[11360:0] info: resolving (init part 2): ns5.gransy.com. AAAA IN
[1588720847] libunbound[11360:0] info: resolving (init part 3): ns5.gransy.com. AAAA IN
[1588720847] libunbound[11360:0] info: processQueryTargets: ns5.gransy.com. AAAA IN
[1588720847] libunbound[11360:0] info: sending query: com. A IN
[1588720847] libunbound[11360:0] debug: sending to target: <.> 198.41.0.4#53
[1588720847] libunbound[11360:0] info: iterator operate: query ns5.gransy.com. A IN
[1588720847] libunbound[11360:0] info: resolving ns5.gransy.com. A IN
[1588720847] libunbound[11360:0] info: resolving (init part 2): ns5.gransy.com. A IN
[1588720847] libunbound[11360:0] info: resolving (init part 3): ns5.gransy.com. A IN
[1588720847] libunbound[11360:0] info: processQueryTargets: ns5.gransy.com. A IN
[1588720847] libunbound[11360:0] debug: sending to target: <.> 2001:500:200::b#53
[1588720847] libunbound[11360:0] info: response for ns5.gransy.com. A IN
[1588720847] libunbound[11360:0] info: reply from <.> 2001:500:200::b#53
[1588720847] libunbound[11360:0] info: sending query: gransy.com. A IN
[1588720847] libunbound[11360:0] debug: sending to target: <com.> 192.12.94.30#53
[1588720847] libunbound[11360:0] info: response for ns5.gransy.com. AAAA IN
[1588720847] libunbound[11360:0] info: reply from <.> 198.41.0.4#53
[1588720847] libunbound[11360:0] debug: sending to target: <com.> 192.41.162.30#53
[1588720847] libunbound[11360:0] info: reply from <com.> 192.12.94.30#53
[1588720847] libunbound[11360:0] info: sending query: ns5.gransy.com. A IN
[1588720847] libunbound[11360:0] debug: sending to target: <gransy.com.> 2a02:750:8::32#53
[1588720847] libunbound[11360:0] info: reply from <com.> 192.41.162.30#53
[1588720847] libunbound[11360:0] debug: sending to target: <gransy.com.> 31.192.227.223#53
[1588720847] libunbound[11360:0] info: reply from <gransy.com.> 2a02:750:8::32#53
[1588720847] libunbound[11360:0] info: finishing processing for ns5.gransy.com. A IN
[1588720847] libunbound[11360:0] info: validator operate: query ns5.gransy.com. A IN
[1588720847] libunbound[11360:0] info: sending query: www.expireddomains.co.za. A IN
[1588720847] libunbound[11360:0] debug: sending to target: <expireddomains.co.za.> 31.192.227.223#53
[1588720847] libunbound[11360:0] info: reply from <gransy.com.> 31.192.227.223#53
[1588720847] libunbound[11360:0] info: sending query: ns5.gransy.com. AAAA IN
[1588720847] libunbound[11360:0] debug: sending to target: <gransy.com.> 77.78.104.149#53
[1588720848] libunbound[11360:0] debug: iterator[module 1] operate: extstate:module_wait_reply event:module_event_reply
[1588720848] libunbound[11360:0] info: iterator operate: query ns5.gransy.com. AAAA IN
[1588720848] libunbound[11360:0] info: response for ns5.gransy.com. AAAA IN
[1588720848] libunbound[11360:0] info: reply from <gransy.com.> 77.78.104.149#53
[1588720848] libunbound[11360:0] info: query response was ANSWER
[1588720848] libunbound[11360:0] info: finishing processing for ns5.gransy.com. AAAA IN
[1588720848] libunbound[11360:0] debug: validator[module 0] operate: extstate:module_state_initial event:module_event_moddone
[1588720848] libunbound[11360:0] info: validator operate: query ns5.gransy.com. AAAA IN
[1588720848] libunbound[11360:0] debug: iterator[module 1] operate: extstate:module_wait_reply event:module_event_pass
[1588720848] libunbound[11360:0] info: iterator operate: query www.expireddomains.co.za. A IN
[1588720848] libunbound[11360:0] info: processQueryTargets: www.expireddomains.co.za. A IN
[1588720848] libunbound[11360:0] info: sanitize: removing extraneous answer RRset: expireddomains.co.za. A IN
[1588720848] libunbound[11360:0] info: response for www.expireddomains.co.za. A IN
[1588720848] libunbound[11360:0] info: reply from <expireddomains.co.za.> 31.192.227.223#53
[1588720848] libunbound[11360:0] info: query response was CNAME
[1588720848] libunbound[11360:0] info: resolving www.expireddomains.co.za. A IN
[1588720848] libunbound[11360:0] info: resolving (init part 2): www.expireddomains.co.za. A IN
[1588720848] libunbound[11360:0] info: resolving (init part 3): www.expireddomains.co.za. A IN
[1588720848] libunbound[11360:0] info: sending query: expireddomains.co.za. A IN
[1588720848] libunbound[11360:0] debug: sending to target: <expireddomains.co.za.> 2a02:750:5::538#53
[1588720848] libunbound[11360:0] info: iterator operate: chased to expireddomains.co.za. A IN
[1588720848] libunbound[11360:0] info: reply from <expireddomains.co.za.> 2a02:750:5::538#53
[1588720848] libunbound[11360:0] info: finishing processing for www.expireddomains.co.za. A IN
[1588720848] libunbound[11360:0] debug: validator[module 0] operate: extstate:module_wait_module event:module_event_moddone
[1588720848] libunbound[11360:0] info: validator operate: query www.expireddomains.co.za. A IN
[1588720848] libunbound[11360:0] info: prime trust anchor
[1588720848] libunbound[11360:0] info: generate keytag query _ta-4a5c-4f66. NULL IN
[1588720848] libunbound[11360:0] debug: validator[module 0] operate: extstate:module_state_initial event:module_event_pass
[1588720848] libunbound[11360:0] info: validator operate: query . DNSKEY IN
[1588720848] libunbound[11360:0] debug: iterator[module 1] operate: extstate:module_state_initial event:module_event_pass
[1588720848] libunbound[11360:0] info: resolving . DNSKEY IN
[1588720848] libunbound[11360:0] info: resolving (init part 2): . DNSKEY IN
[1588720848] libunbound[11360:0] info: resolving (init part 3): . DNSKEY IN
[1588720848] libunbound[11360:0] info: processQueryTargets: . DNSKEY IN
[1588720848] libunbound[11360:0] info: sending query: . DNSKEY IN
[1588720848] libunbound[11360:0] debug: sending to target: <.> 2001:503:ba3e::2:30#53
[1588720848] libunbound[11360:0] info: validator operate: query _ta-4a5c-4f66. NULL IN
[1588720848] libunbound[11360:0] info: resolving _ta-4a5c-4f66. NULL IN
[1588720848] libunbound[11360:0] info: resolving (init part 2): _ta-4a5c-4f66. NULL IN
[1588720848] libunbound[11360:0] info: resolving (init part 3): _ta-4a5c-4f66. NULL IN
[1588720848] libunbound[11360:0] info: processQueryTargets: _ta-4a5c-4f66. NULL IN
[1588720848] libunbound[11360:0] info: sending query: _ta-4a5c-4f66. A IN
[1588720848] libunbound[11360:0] debug: sending to target: <.> 2001:500:2d::d#53
[1588720848] libunbound[11360:0] info: iterator operate: query . DNSKEY IN
[1588720848] libunbound[11360:0] info: response for . DNSKEY IN
[1588720848] libunbound[11360:0] info: reply from <.> 2001:503:ba3e::2:30#53
[1588720848] libunbound[11360:0] info: finishing processing for . DNSKEY IN
[1588720848] libunbound[11360:0] info: validate keys with anchor(DS): sec_status_secure
[1588720848] libunbound[11360:0] info: Successfully primed trust anchor . DNSKEY IN
[1588720848] libunbound[11360:0] debug: validator[module 0] operate: extstate:module_wait_subquery event:module_event_pass
[1588720848] libunbound[11360:0] info: validated DS za. DS IN
[1588720848] libunbound[11360:0] info: validator operate: query za. DNSKEY IN
[1588720848] libunbound[11360:0] info: resolving za. DNSKEY IN
[1588720848] libunbound[11360:0] info: resolving (init part 2): za. DNSKEY IN
[1588720848] libunbound[11360:0] info: resolving (init part 3): za. DNSKEY IN
[1588720848] libunbound[11360:0] info: processQueryTargets: za. DNSKEY IN
[1588720848] libunbound[11360:0] info: sending query: za. DNSKEY IN
[1588720848] libunbound[11360:0] debug: sending to target: <za.> 204.61.216.55#53
[1588720848] libunbound[11360:0] info: iterator operate: query za. DNSKEY IN
[1588720848] libunbound[11360:0] info: response for za. DNSKEY IN
[1588720848] libunbound[11360:0] info: reply from <za.> 204.61.216.55#53
[1588720848] libunbound[11360:0] info: finishing processing for za. DNSKEY IN
[1588720848] libunbound[11360:0] info: validated DNSKEY za. DNSKEY IN
[1588720848] libunbound[11360:0] info: validated DS co.za. DS IN
[1588720848] libunbound[11360:0] info: validator operate: query co.za. DNSKEY IN
[1588720848] libunbound[11360:0] info: resolving co.za. DNSKEY IN
[1588720848] libunbound[11360:0] info: resolving (init part 2): co.za. DNSKEY IN
[1588720848] libunbound[11360:0] info: resolving (init part 3): co.za. DNSKEY IN
[1588720848] libunbound[11360:0] info: processQueryTargets: co.za. DNSKEY IN
[1588720848] libunbound[11360:0] info: sending query: co.za. DNSKEY IN
[1588720848] libunbound[11360:0] debug: sending to target: <co.za.> 196.4.160.17#53
[1588720848] libunbound[11360:0] info: iterator operate: query _ta-4a5c-4f66. NULL IN
[1588720848] libunbound[11360:0] info: response for _ta-4a5c-4f66. NULL IN
[1588720848] libunbound[11360:0] info: reply from <.> 2001:500:2d::d#53
[1588720848] libunbound[11360:0] info: query response was NXDOMAIN ANSWER
[1588720848] libunbound[11360:0] info: finishing processing for _ta-4a5c-4f66. NULL IN
[1588720848] libunbound[11360:0] info: iterator operate: query co.za. DNSKEY IN
[1588720848] libunbound[11360:0] info: response for co.za. DNSKEY IN
[1588720848] libunbound[11360:0] info: reply from <co.za.> 196.4.160.17#53
[1588720848] libunbound[11360:0] info: finishing processing for co.za. DNSKEY IN
[1588720848] libunbound[11360:0] info: validated DNSKEY co.za. DNSKEY IN
[1588720848] libunbound[11360:0] info: NSEC3s for the referral proved no DS.
[1588720848] libunbound[11360:0] info: Verified that response is INSECURE
[1588720848] libunbound[11360:0] debug: validator[module 0] operate: extstate:module_state_initial event:module_event_new
[1588720848] libunbound[11360:0] info: validator operate: query www.expireddomains.co.za. AAAA IN
[1588720848] libunbound[11360:0] info: resolving www.expireddomains.co.za. AAAA IN
[1588720848] libunbound[11360:0] info: resolving (init part 2): www.expireddomains.co.za. AAAA IN
[1588720848] libunbound[11360:0] info: resolving (init part 3): www.expireddomains.co.za. AAAA IN
[1588720848] libunbound[11360:0] info: processQueryTargets: www.expireddomains.co.za. AAAA IN
[1588720848] libunbound[11360:0] info: sending query: www.expireddomains.co.za. A IN
[1588720848] libunbound[11360:0] debug: sending to target: <expireddomains.co.za.> 77.78.126.35#53
[1588720849] libunbound[11360:0] debug: iterator[module 1] operate: extstate:module_wait_reply event:module_event_reply
[1588720849] libunbound[11360:0] info: iterator operate: query www.expireddomains.co.za. AAAA IN
[1588720849] libunbound[11360:0] info: sanitize: removing extraneous answer RRset: expireddomains.co.za. A IN
[1588720849] libunbound[11360:0] info: response for www.expireddomains.co.za. AAAA IN
[1588720849] libunbound[11360:0] info: reply from <expireddomains.co.za.> 77.78.126.35#53
[1588720849] libunbound[11360:0] info: query response was CNAME
[1588720849] libunbound[11360:0] info: resolving www.expireddomains.co.za. AAAA IN
[1588720849] libunbound[11360:0] info: resolving (init part 2): www.expireddomains.co.za. AAAA IN
[1588720849] libunbound[11360:0] info: resolving (init part 3): www.expireddomains.co.za. AAAA IN
[1588720849] libunbound[11360:0] info: processQueryTargets: www.expireddomains.co.za. AAAA IN
[1588720849] libunbound[11360:0] info: sending query: expireddomains.co.za. AAAA IN
[1588720849] libunbound[11360:0] debug: sending to target: <expireddomains.co.za.> 77.78.126.35#53
[1588720849] libunbound[11360:0] debug: iterator[module 1] operate: extstate:module_wait_reply event:module_event_noreply
[1588720849] libunbound[11360:0] info: iterator operate: chased to expireddomains.co.za. AAAA IN
[1588720849] libunbound[11360:0] debug: sending to target: <expireddomains.co.za.> 2001:19f0:5401:69b:5400:1ff:fec5:8f3f#53
[1588720850] libunbound[11360:0] debug: iterator[module 1] operate: extstate:module_wait_reply event:module_event_reply
[1588720850] libunbound[11360:0] info: iterator operate: query www.expireddomains.co.za. AAAA IN
[1588720850] libunbound[11360:0] info: iterator operate: chased to expireddomains.co.za. AAAA IN
[1588720850] libunbound[11360:0] info: response for www.expireddomains.co.za. AAAA IN
[1588720850] libunbound[11360:0] info: reply from <expireddomains.co.za.> 2001:19f0:5401:69b:5400:1ff:fec5:8f3f#53
[1588720850] libunbound[11360:0] info: query response was ANSWER
[1588720850] libunbound[11360:0] info: processQueryTargets: www.expireddomains.co.za. AAAA IN
[1588720850] libunbound[11360:0] info: sending query: expireddomains.co.za. AAAA IN
[1588720850] libunbound[11360:0] debug: sending to target: <expireddomains.co.za.> 2001:19f0:6801:474:5400:1ff:fec5:8efb#53
[1588720850] libunbound[11360:0] info: reply from <expireddomains.co.za.> 2001:19f0:6801:474:5400:1ff:fec5:8efb#53
[1588720850] libunbound[11360:0] info: finishing processing for www.expireddomains.co.za. AAAA IN
[1588720850] libunbound[11360:0] debug: validator[module 0] operate: extstate:module_wait_module event:module_event_moddone
[1588720850] libunbound[11360:0] info: validator operate: query www.expireddomains.co.za. AAAA IN
[1588720850] libunbound[11360:0] info: NSEC3s for the referral proved no DS.
[1588720850] libunbound[11360:0] info: Verified that response is INSECURE
expireddomains.co.za has IPv6 address 2a03:6920:0:cafe::add (insecure)
[1588720850] libunbound[11360:0] debug: validator[module 0] operate: extstate:module_state_initial event:module_event_new
[1588720850] libunbound[11360:0] info: validator operate: query www.expireddomains.co.za. MX IN
[1588720850] libunbound[11360:0] debug: iterator[module 1] operate: extstate:module_state_initial event:module_event_pass
[1588720850] libunbound[11360:0] info: resolving www.expireddomains.co.za. MX IN
[1588720850] libunbound[11360:0] info: resolving (init part 2): www.expireddomains.co.za. MX IN
[1588720850] libunbound[11360:0] info: resolving (init part 3): www.expireddomains.co.za. MX IN
[1588720850] libunbound[11360:0] info: processQueryTargets: www.expireddomains.co.za. MX IN
[1588720850] libunbound[11360:0] info: sending query: www.expireddomains.co.za. A IN
[1588720850] libunbound[11360:0] debug: sending to target: <expireddomains.co.za.> 109.74.7.71#53
[1588720851] libunbound[11360:0] debug: iterator[module 1] operate: extstate:module_wait_reply event:module_event_reply
[1588720851] libunbound[11360:0] info: iterator operate: query www.expireddomains.co.za. MX IN
[1588720851] libunbound[11360:0] info: sanitize: removing extraneous answer RRset: expireddomains.co.za. A IN
[1588720851] libunbound[11360:0] info: response for www.expireddomains.co.za. MX IN
[1588720851] libunbound[11360:0] info: reply from <expireddomains.co.za.> 109.74.7.71#53
[1588720851] libunbound[11360:0] info: query response was CNAME
[1588720851] libunbound[11360:0] info: resolving www.expireddomains.co.za. MX IN
[1588720851] libunbound[11360:0] info: resolving (init part 2): www.expireddomains.co.za. MX IN
[1588720851] libunbound[11360:0] info: resolving (init part 3): www.expireddomains.co.za. MX IN
[1588720851] libunbound[11360:0] info: processQueryTargets: www.expireddomains.co.za. MX IN
[1588720851] libunbound[11360:0] info: sending query: expireddomains.co.za. MX IN
[1588720851] libunbound[11360:0] debug: sending to target: <expireddomains.co.za.> 95.179.192.121#53
[1588720851] libunbound[11360:0] info: iterator operate: chased to expireddomains.co.za. MX IN
[1588720851] libunbound[11360:0] info: reply from <expireddomains.co.za.> 95.179.192.121#53
[1588720851] libunbound[11360:0] info: query response was ANSWER
[1588720851] libunbound[11360:0] info: finishing processing for www.expireddomains.co.za. MX IN
[1588720851] libunbound[11360:0] debug: validator[module 0] operate: extstate:module_wait_module event:module_event_moddone
[1588720851] libunbound[11360:0] info: validator operate: query www.expireddomains.co.za. MX IN
[1588720851] libunbound[11360:0] info: NSEC3s for the referral proved no DS.
[1588720851] libunbound[11360:0] info: Verified that response is INSECURE
If you use ns.domainname.com, you should always use Glue records. So there are too many steps -> my local Unbound runs, the Unbound of Letsencrypt stops, too many steps.
