Wildcard Certificates Using Multiple Cloudflare accounts
Hi there I have multiple domains that are all currently using SSL certificates on LetsEncrypt, however I wish to move to DNS based authentication across all of the domains. I have successfully set up the domains that are attached to a single account as detailed here: https://certbot.eff.org/instructions
I would like to know if it’s possible to configure the secrets file and/or cloudflare plugin to use more than one cloudflare account, as all the domains I wish to authenticate are not on the same account and therefore cannot use the same API token.
Any help is appreciated,
Thanks
Server version: Apache/2.4.34 (Ubuntu 18.10)
Certbot Version: certbot 0.27.0
[taking a wild guess here]
Have you tried calling the DNS API twice?
something like:
certbot certonly \
 --dns-cloudflare \
 --dns-cloudflare-credentials ~/.secrets/certbot/cloudflare#1.ini \
 -d example1.com \
 --dns-cloudflare \
 --dns-cloudflare-credentials ~/.secrets/certbot/cloudflare#2.ini \
 -d example2.com
If it can’t be done using one file with multiple sections or something similar this would be excellent. Thank you!
