WildCard certificate issue
I have issuer:
apiVersion: certmanager.k8s.io/v1alpha1
kind: ClusterIssuer
metadata:
spec:
  acme:
    email: test@test
    server: https://acme-staging-v02.api.letsencrypt.org/directory
    privateKeySecretRef:
    dns01:
      providers:
        - name: prod-dns
          clouddns:
            serviceAccountSecretRef:
              key: service-account.json
            project: test
And want to create wild card certificate
kind: Certificate
metadata:
  namespace: default
spec:
  secretName: test-tls
  issuerRef:
    kind: ClusterIssuer
  commonName: "*cert-manager.test.com"
  dnsNames:
  - cert-manager.test.com
  acme:
    config:
    - dns01:
        provider: prod-dns
      domains:
      - "*cert-manager.test.com"
and getting next error:
Events:
Type Reason Age From Message
Warning ErrCreateOrder 1s cert-manager Error creating order: acme: urn:ietf:params:acme:error:malformed: Error creating new order :: DNS name had a malformed wildcard label
Hi @aaktaev
you must use
*.cert-manager.test.com
Wildcard, dot, then the domain name. But you must be owner of the domain. So if you are not owner of test.com, that will not work.
Thanks!It helped. Issue can be closed.
