*.chargerback.net
wacs
it tried to DNS validate the domain names separately and failed
IIS 10
Windows Server 2016
Self
Yes
No
or certbot-auto --version
if you're using Certbot): WACS version 2.1.19.1138 (release, pluggable, standalone, 64-bit)
My site normally uses a wildcard certificate *.chargerback.net. I have successfully used WACS to generate/auto install for the last 10 renewals. However, I have had to add bindings for two additional domain names, that I don't need LetsEncrypt certificates for. But when I try to run WACS to generate the certificate, it asks me about the bindings, then tries to create a separate certificate for each one. This fails because (I assume) the subdomains of chargerback.net are CNAMEs. Is there any way to get WACS to generate a wildcard certificate and bind to the correct subdomains?
