Wildcard cert and DNS Challange with certbot
My domain is: nawrocki.eu
certbot -d nawrocki.eu -d *.nawrocki.eu --server https://acme-v02.api.letsencrypt.org/directory --manual --preferred-challenges dns certonly
root@vps:/etc/letsencrypt# ./enpe.pl
dns-01 challenge for nawrocki.eu
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you're running certbot in manual mode on a machine that is not
your server, please ensure you're okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: y
Please deploy a DNS TXT record under the name
_acme-challenge.nawrocki.eu with the following value:
aShMwD-Rji_sgU44xyHMu_ViMKaZIzo_QB7XGZa1j2A
Before continuing, verify the record is deployed.
Press Enter to Continue
gYKs4q2DsUUOIZK4eeq8RujqtJRkK6KcmzKL3-ltd8s
Failed authorization procedure. nawrocki.eu (dns-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect TXT recor d "gYKs4q2DsUUOIZK4eeq8RujqtJRkK6KcmzKL3-ltd8s" found at _acme-challenge.nawrocki.eu,
    Domain: nawrocki.eu
    Detail: Incorrect TXT record
root@vps:/etc/letsencrypt# apache2 -v
Server version: Apache/2.4.29 (Ubuntu)
Server built: 2018-10-10T18:59:25
root@vps:/etc/letsencrypt# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.1 LTS
Release: 18.04
Codename: bionic
OVH
no
You need to add both TXT records:
I only see one right now:
_acme-challenge.nawrocki.eu text =
If for any reason the second record overwrites the first one; so that only one record can exist at a time:
Try adding them both at the same time (with a line break between them).
