./certbot-auto renew --dry-run
Processing /etc/letsencrypt/renewal/www.domain.com.conf
Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
tls-sni-01 challenge for www.domain.com
tls-sni-01 challenge for sub1.domain.com
tls-sni-01 challenge for domain.com
tls-sni-01 challenge for sub2.domain.com
Generating key (2048 bits): /etc/letsencrypt/keys/0009_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0009_csr-certbot.pem
/etc/letsencrypt/live/www.domain.com/fullchain.pem (success)
The cron log says it’s running just fine… but it doesn’t upgrade the certificates. I want this cron’d so I don’t have to run it manually every time they are about to expire.
Have you got your cron set up to email you the output ? if so, what ouput does the command give ?
If you run the command yourself ( /usr/sbin/certbot-auto renew --no-self-upgrade ) does it renew OK ? if so, then it’s probably your PATH being different in the cron.
No idea how to do the mail. Path is definitely not different or wrong.
If I run certbot-auto renew --new-self-upgrade from the command line and it works I won’t be able to know if cron is going to work until 3 months from now which is what I’m trying to avoid. I’m trying to resolve this once and for all so it will just run on its own.
By PATH I mean the environment PATH variable, not the path to the command "/usr/sbin/". I'd be surprised if the PATH variable was exactly the same. You can see what it is interactively by running
What does the path have to do with it if I have the full path directly to the file in my crontab and when I run it from the command line? I can see from the syslog that it’s executing anyway.
The PATH is important because it shows where the program should look for other applications / scripts it needs - which would fail if it can’t find them.
The question is what is your PATH in the cron - you could echo $PATH in a cron - and place it in a file - then you can see what the difference is. Alternatively you could modify the PATH variable in your current cron ( ignoring the “games” ones, as they are not likely to be needed.
