Hi my certificate has expired a day ago
and i am trying to renew it but nothing helps
even the auto renew is not helping
please guide me here
Hello.
Please provide more information.
I can login to a root shell on my machine (yes or no, or I donât know):
Iâm using a control panel to manage my site (no, or provide the name and version of the control panel):
domain: highwaydelight.in
sudo certbot renew --dry-run
i stopped apache and and run above command and restarted the apache server
operating system is ubuntu 16.04
i can log into my root
i got this output
new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/highwaydelight.in/fullchain.pem
** DRY RUN: simulating âcertbot renewâ close to cert expiry
/etc/letsencrypt/live/highwaydelight.in/fullchain.pem (success)
Hi @manojrammurthy,
--dry-run means something like âtestâ or âexperimentâ and itâs meant for use to see if your configuration would work for a renewal. If you want to renew the certificate, you should instead use certbot renew, without the --dry-run option.
