My domain is: svn.boberglund.com
I ran this command: sudo certbot renew --dry-run
The following certs could not be renewed:
/etc/letsencrypt/live/svn.boberglund.com/fullchain.pem (failure)
The following certs were successfully renewed:
/etc/letsencrypt/live/video.boberglund.com/fullchain.pem (success)
Server version: Apache/2.4.29 (Ubuntu)
Server built: 2019-07-16T18:14:45
The operating system my web server runs on is (include version): Ubuntu 18.04.3 LTS
My hosting provider, if applicable, is: none
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
My Ubuntu server sits on my home LAN with dynamic dns pointing to the fiber router’s Internet address.
I have forwarded ports 80 and 443 on the router to the Ubuntu server’s internal address. The server is used for my videos and for subversion.
Originally Apache was set up as part of installation of Apache Subversion and used a self-signed certificate. Later I added my video site as a virtual host into Apache and used certbot to get a cert that would not barf at you every time in a browser.
I used instructions on how to retrieve a cert to be used with subversion on Digital ocean and thought that I was all done…
However now that I checked the renewal process as described above I see that the cert for svn will not be renewed. What to do???
