Hi all
I am trying to setup DNS01 for my subdomains and have done the following:
sudo certbot certonly \
--dns-digitalocean \
--dns-digitalocean-credentials dns-secret.ini \
-d "*.tool.databaker.io" \
-d "*.service.databaker.io"
As the ouput I’ve got:
Plugins selected: Authenticator dns-digitalocean, Installer None
Enter email address (used for urgent renewal and security notices) (Enter 'c' to
cancel): example@example.io
agree in order to register with the ACME server at
https://acme-v02.api.letsencrypt.org/directory
(A)gree/(C)ancel: A
Would you be willing to share your email address with the Electronic Frontier
Foundation, a founding partner of the Let's Encrypt project and the non-profit
organization that develops Certbot? We'd like to send you email about our work
encrypting the web, EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: Y
dns-01 challenge for service.databaker.io
dns-01 challenge for tool.databaker.io
Unsafe permissions on credentials configuration file: dns-secret.ini
Waiting 10 seconds for DNS changes to propagate
/etc/letsencrypt/live/tool.databaker.io/fullchain.pem
/etc/letsencrypt/live/tool.databaker.io/privkey.pem
Your cert will expire on 2020-08-03. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew *all* of your certificates, run
"certbot renew"
Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
As you can see, I do not receive any TXT for DNS entries. What am I doing wrong?
Thanks
