Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: cs.isatel.tj
I ran this command: sudo certbot --nginx
It produced this output: DNS problem: NXDOMAIN looking up A for cs.isatel.tj - check
that a DNS record exists for this domain
My web server is (include version): nginx 1.10.3
The operating system my web server runs on is (include version): Ubuntu 16.04
My hosting provider, if applicable, is: isatel.tj
I can login to a root shell on my machine (yes or no, or I don’t know): I don’t know
Your host cs.isatel.tj doesn't have any IP address / CNAME records, which is why it's returning NXDOMAIN.
Please enter your desired IP address with A record for that subdomain in order for HTTP based validation to work.
It’s possible that this name is used internally on your own network via an internal DNS service or a hosts file, but the name has to be publicly visible for the rest of the Internet in order for Let’s Encrypt to issue a certificate for it by this method.
there is isatel.tj no such service as domain issuance on this site.
I don’t know where to get the original domain with an A or CNAME record. I live in Tajikistan, so by the way.
I chose the name cs randomly, “invented it myself” is my test server and I build it on VMware. I thought if everything worked out for me, I’ll go to a real full-fledged server. I invented domains myself.
@shohrukh, @JimPas’s explanation is correct—Let’s Encrypt isn’t able to issue certificates for names that you made up yourself. They have to be visible in the public DNS records, as displayed by the authoritative DNS server for the domain.
