DNS problem NXDOMAIN
www.crazztor.com
certbot --nginx
    Domain: www.mail.crazztor.com
    Type: None
    Detail: DNS problem: NXDOMAIN looking up A for
    www.mail.crazztor.com - check that a DNS record exists for this
    domain
    Domain: www.dev.crazztor.com
    Type: None
    Detail: DNS problem: NXDOMAIN looking up A for www.dev.crazztor.com
    • check that a DNS record exists for this domain
      nginx 1.14.2
      debian 10
      linode
      no
      The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.31.0
Hi @sudobyter, and welcome to the LE community forum :slight_smile:
Did you spell that name correctly ("crazztor.com")?
[Is it "crazytor.com"?]
yup it's spelled correctly crazztor -Crazy + transistor- you can check the domain up "crazztor.com"
sooo sorry my bad , had to add the wild card in my subdomain then for the www.mail my host doesn't support sub.sub.example.com so I did it manually and it worked !
I did it
it was host issue dosen't support sub.sub.domain
I had to do it manually
and I had to use the wild card
thank you !
