What webroot to choose when deploying certbot on Ubuntu 14.04.5, with Nginx and Discourse installed?
root@iosre:/var# ./certbot-auto certonly
Failed to find apache2ctl in PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
1: Place files in webroot directory (webroot)
2: Spin up a temporary webserver (standalone)
Please enter in your domain name(s) (comma and/or space separated)  (Enter 'c'
to cancel):iosre.com
http-01 challenge for iosre.com
Select the webroot for iosre.com:
1: Enter a new webroot
Press 1 [enter] to confirm the selection (press 'c' to cancel): 1
Input the webroot for iosre.com: (Enter 'c' to cancel):www
Failed authorization procedure. iosre.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://iosre.com/.well-known/acme-challenge/XEW4lPlZXcex19zjJAqLUui7uYisNcBB3MiR-gvuL4c: "<!DOCTYPE html>
<html lang="en">
<head>
  <meta charset="utf-8">
  <title>iOSRE</title>
  <meta name="description" content="">
   Domain: iosre.com
   Type:   unauthorized
   Detail: Invalid response from
   "<!DOCTYPE html>
   <html lang="en">
   <head>
root@iosre:/var#
FYI. What did I do wrong?
If you need any more info, please let me know. Thank you!
Yinglu
The webroot is the actual path on your webserver where the content of your website resides. E.g., /var/www/example.com/htdocs/ (or equivalent on your server…)
