What may cause "Your connection isn't private" when running certsage.php from a web browser?
I host a MediaWiki website on Namcheap shared hosting on public_html/example.com.
I have uploaded certsage.txt to that directory and then changed the file name from certsage.txt to certsage.php.
My problem is that I got "Your connection isn't private" when I ran in the web browser example.com/certsage.php.
Connecting over HTTP would cause that. So would using an invalid certificate.
It's beneficial to fill out the template when posting in the Help category. That allows Community members to examine things and provide better answers.
You're using Certsage to get a certificate. That probably means you don't have a certificate yet. Thus, the connection isn't private warning is to be expected, as that would require a certificate you don't have yet.
Your browser should be able to bypass this warning just this once to get past this catch-22. Once you've got your cert and installed it, including HTTP to HTTPS redirect, the warning should go away (probably need to clear your browsers cache to make sure).
