My domain is: abragam.imt.kit.edu
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: abragam.imt.kit.edu
2: www.abragam.imt.kit.edu
Requesting a certificate for abragam.imt.kit.edu and www.abragam.imt.kit.edu
Domain: abragam.imt.kit.edu
Type: connection
Detail: 141.52.156.23: Fetching http://abragam.imt.kit.edu/.well-known/acme-challenge/95To-8uKY0ju0JvOETjEzuDrFeA-Eb_PEgZESyPAhcc: Connection refused
Domain: www.abragam.imt.kit.edu
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for www.abragam.imt.kit.edu - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for www.abragam.imt.kit.edu - check that a DNS record exists for this domain
My web server is (include version): Apache2
The operating system my web server runs on is (include version): Ubuntu 22.04.4 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
