Website url "lock" does not reflect updated certificate
allcountyguitar.com
sudo ./certbot-auto certonly --debug
Please enter in your domain name(s) (comma and/or space separated) (Enter ‘c’
to cancel): allcountyguitar.com
    /etc/letsencrypt/live/allcountyguitar.com-0001/fullchain.pem
    /etc/letsencrypt/live/allcountyguitar.com-0001/privkey.pem
    Your cert will expire on 2020-10-27.
    Server version: Apache/2.4.43 (Amazon)
    Server built: May 14 2020 18:12:28
NAME=“Amazon Linux AMI”
VERSION=“2018.03”
bash
certbot --version
bash: certbot: command not found
Problem Statement:
Upon renewing from by bash cmd window I get message that the new expiration date for the renewed certificate will be 10/27/2020, however checking the “lock” icon (waiting an hour after recert) it maintains the old expiration date: Friday, August 14, 2020
Hi @kiteandwindsurfer
your command uses certonly. Did you restart your webserver?
Yes, restarted web server
Stopping httpd: [ OK ]
Starting httpd: [ OK ]
No change to date of recert
thank you for your response!
best,
Brain
Hi @kiteandwindsurfer,
This part is the problem. You can see that Certbot said it was "creating a new certificate" and it saved it in a different place (/etc/letsencrypt/live/allcountyguitar.com-0001 instead of /etc/letsencrypt/live/allcountyguitar.com). Your web server application has not been configured to use this new path, so it doesn't notice this certificate.
The reason for this behavior by Certbot is that your old certificate covers both allcountyguitar.com and another domain, enetapplication.com. But when you asked for the new certificate, you didn't mention the second domain, so Certbot concluded that you must want a new, separate certificate that only covers allcountyguitar.com without enetapplication.com. It then went ahead and got that certificate, saving it in a new location that your web server application doesn't know anything about.
I would suggest deleting this unused new certificate with certbot delete, unless you specifically wanted enetapplication.com to no longer be covered by a certificate. After that, you can use the normally-recommended certbot renew to renew your existing certificate.
certbot renew has various advantages over certbot certonly for a renewal:
  • It only tries to renew certificates that are less than one month from expiry, so it's safe to run it very frequently (we recommend twice per day)
  • It uses your existing certificates on disk to decide which domain names and file locations to use, without changing anything
  • It tries to renew any Certbot-created certificates on your system that are in need of a renewal, in one single invocation of the Certbot command
that is fantastic - thank you so much and kind of realized that this was a quality organization when I joined and now see that in fact it is what I thought, careful and responsive thanks to the membership
thanks again, will proceed from here
best,
Brian
(fyi) when originally installing I used:
wget https://dl.eff.org/certbot-auto
Please point me to what I need to do to delete /etc/letsencrypt/live/allcountyguitar.com-0001
I have tried:
#sudo certbot delete
sudo: certbot: command not found
When creating the certificates I follow these steps:
  1. #sudo ./certbot-auto certonly --debug
  2. Select option #1: 1: Apache Web Server plugin (apache)
  3. Type in domain name
  4. Restart httpd
Once deleted I would to avail myself of this:
To non-interactively renew all of your certificates, run "certbot-auto renew"
...but get the same "command not found" message
Again, many thanks in advance!
best,
Brian
certbot and certbot-auto are synonyms depending on the way you installed Certbot on your particular system. So for both commands you should use ./certbot-auto instead of certbot in the command.
thank you, this worked for all my certs:
sudo ./certbot-auto renew --debug
It still tries:
Processing /etc/letsencrypt/renewal/allcountyguitar.com-0001.conf
Cert not yet due for renewal
I need to clean up others that threw errors but all domains were processed, and the domain allcountyguitar.com "lock" is now showing the renewed expiration date!
thanks again for the support
best,
Brian
