Website does not load correct in chrome
My domain is: all-about-controls.com
I ran this command: sudo apache2ctl configtest
It produced this output: Syntax OK
The operating system my web server runs on is (include version): Ubuntu 24.04.2 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot --version certbot 2.9.0
The site is loading perfect on Firefox and Safari, but not on Chrome.
Failed to load resource: net::ERR_CERT_COMMON_NAME_INVALID
What can be wrong ?
Welcome @Jurg
The problem is because the certificate you just got has only the domain name www.all-about-controls.com.
So, requests to your apex domain https://all-about-controls.com/ will fail as the cert does not also have this name. See this test site for example: SSL Checker
What command did you run to get the certificate? Once we know that we can offer advice on how to fix this.
Hello,
To make the certificate i have used ; 1. sudo certbot --apache
Output
Enter email address (used for urgent renewal and security notices)
 (Enter 'c' to cancel): you@your_domain
agree in order to register with the ACME server at
https://acme-v02.api.letsencrypt.org/directory
(Y)es/(N)o: Y
Would you be willing to share your email address with the Electronic Frontier
Foundation, a founding partner of the Let's Encrypt project and the non-profit
organization that develops Certbot? We'd like to send you email about our work
encrypting the web, EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: N
Hmm. Normally that would show you a list of domain names to put in the certificate.
Would you show what Apache has for your VirtualHosts?
sudo apache2ctl -t -D DUMP_VHOSTS
VirtualHost configuration:
*:443 all-about-controls.com (/etc/apache2/sites-enabled/opencart-le-ssl.conf:2)
*:80 all-about-controls.com (/etc/apache2/sites-enabled/opencart.conf:1)
That's unusual. It only shows your apex domain and not your www subdomain at all. Yet, the www subdomain is what is in the certificate.
Please also show output of this:
sudo certbot certificates
and the contents of this file
Found the following certs:
Certificate Name: www.all-about-controls.com
Serial Number: 626a85c660a5d06e9873570842db59437fd
Key Type: ECDSA
Domains: www.all-about-controls.com
Expiry Date: 2025-07-19 06:08:22+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/www.all-about-controls.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.all-about-controls.com/privkey.pem
<IfModule mod_ssl.c>
<VirtualHost *:443>
    ServerAdmin admin@all-about-controls.com
    DocumentRoot /var/www/html/opencart/upload/
    ServerName all-about-controls.com
    ServerAlias www.all-about-controls.com
    <Directory /var/www/html/opencart/upload/>
        Options FollowSymLinks
        AllowOverride All
        Order allow,deny
        Allow from all
    </Directory>
    ErrorLog /var/log/apache2/yourdomain.com-error_log
    CustomLog /var/log/apache2/yourdomain.com-access_log common
SSLCertificateFile /etc/letsencrypt/live/www.all-about-controls.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/www.all-about-controls.com/privkey.pem
</VirtualHost>
</IfModule>
Try this as a test. If this works we will use a very different command to get the production cert. This is just a test. Just let us know the result.
sudo certbot certonly --dry-run --apache --cert-name www.all-about-controls.com -d www.all-about-controls.com -d all-about-controls.com
You are updating certificate www.all-about-controls.com to include new
domain(s):
You are also removing previously included domain(s):
(None)
Did you intend to make this change?
(U)pdate certificate/(C)ancel: U
Simulating renewal of an existing certificate for www.all-about-controls.com and all-about-controls.com
The dry run was successful.
Excellent. Now do this and you should be good. You will get a new cert with both domain names and Apache will be reloaded so will start using it right away
sudo certbot --apache --cert-name www.all-about-controls.com -d www.all-about-controls.com -d all-about-controls.com
Note: We dropped certonly --dry-run from the earlier test command.
You may need to restart your browser(s) for it to see the new cert. They often cache the previous one
Serial Number: 6ee45220fb5940f42aa6aba38e4eb18e981
Key Type: ECDSA
Domains: www.all-about-controls.com all-about-controls.com
Expiry Date: 2025-07-19 17:27:47+00:00 (VALID: 89 days)
Excellent. Does it all look good to you now? Looks good to me.
Yes !!!!
Thanks for your time, thanks.
The site load good now, great.
