SSL not loading
My domain is:mail.isitwetyet.com
I ran this command:certbot --apache
The operating system my web server runs on is (include version): centos 7
I recently installed certbot on this machine and was using it until last night, but early this morning. I find my self that the ssl for my domain is not loading and I’m not sure which certificate it’s using.
help please.
Hi @blackwing
you have created two certificates - https://check-your-website.server-daten.de/?q=mail.isitwetyet.com#ct-logs
Let's Encrypt Authority X3 2019-10-22 2020-01-20 mail.isitwetyet.com
1 entries duplicate nr. 2
Let's Encrypt Authority X3 2019-10-16 2020-01-14 mail.isitwetyet.com
1 entries duplicate nr. 1
Let's Encrypt Authority X3 2019-10-09 2020-01-07 mail.isitwetyet.com
1 entries
But you don't use one of these, instead, you use a self signed certificate.
What says
apachectl -S
Main DocumentRoot: "/var/www/html/webmail"
Main ErrorLog: "/etc/httpd/logs/error_log"
Mutex proxy-balancer-shm: using_defaults
Mutex authdigest-client: using_defaults
Mutex proxy: using_defaults
Mutex authn-socache: using_defaults
Mutex default: dir="/run/httpd/" mechanism=default
Mutex authdigest-opaque: using_defaults
PidFile: "/run/httpd/httpd.pid"
Define: _RH_HAS_HTTPPROTOCOLOPTIONS
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="apache" id=48
Group: name="apache" id=48
last night it was actually OK.
On my apache httpd.conf I have this line
IncludeOptional sites-enabled/*.conf
in which the configuration has this
SSLCertificateFile /etc/letsencrypt/live/mail.isitwetyet.com/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/mail.isitwetyet.com/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/mail.isitwetyet.com/chain.pem
I’m not sure why, but my system is using the default certificate of the apache from conf.d and had to replace the one on ssl.conf with the certificate issued by certbot and that works for now.
There is no vHost visible. So no is defined or all vHosts are disabled.
So only the standard vHost is used.
apachectl -S should show that - but there is no output.
I actually have another domain on the same domain, but was working perfectly.
