My domain is: robin-kok.nl
I ran this command: Everything from: https://certbot.eff.org/lets-encrypt/centosrhel7-apache.html
It produced this output: Installed cerificate, but not using it.
My web server is (include version): Cloud Server
The operating system my web server runs on is (include version): CentOS 7.5
My hosting provider, if applicable, is: Neostrada | Powered by Totaalcloud.nl
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): DirectAdmin
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.38.0
EDIT: It’s currently using a self signed certificate.
Hi @Cookooloo
that's too unspecific. The first part is the installation. But what was your certificate creation command?
And checking your domain you have created the wrong certificate - https://check-your-website.server-daten.de/?q=robin-kok.nl
| Issuer |
not before |
not after |
Domain names |
LE-Duplicate |
next LE |
| Let's Encrypt Authority X3 |
2019-09-26 |
2019-12-25 |
robin-kok.nl - 1 entries |
duplicate nr. 1 |
The certificate has only one domain name, not two.
So first step: What says
apachectl -S
@JuergenAuer
The commands I ran:
yum install epel-release
yum -y install yum-utils
yum-config-manager --enable rhui-REGION-rhel-server-extras rhui-REGION-rhel-server-optional
sudo yum install certbot
sudo certbot certonly --webroot
Also, I ran apachectl -S and it gives me a lot of information.
I’ll type it out and edit this post.
apachectl -S:
default server localhost
namevhost localhost
namevhost www.robin-kok.nl
alias www.robin-kok.nl
alial robin-kok.nl
namevhost www.poortwachter.robin-kok.nl
alias www.poortwachter.robin-kok.nl
alias poortwachter.robin-kok.nl
all of these have 2 entries, with port 80 and port 443.
Do I need to add more?
That's
your answer. certonly doesn't create a port 443 vHost and doesn't install a certificate.
Last step: Use
sudo certbot -d robin-kok.nl -d www.robin-kok.nl --apache
instead.
But first your vHost configuration is required to see, if you have a correct port 80 vHost with both domain names.
@JuergenAuer
Does this also get the subdomain?
Message:
The requested apache plugin does not appear to be installed
Hi @JuergenAuer,
I tried some more steps but I’m getting a new error now:
Command:
Error:
The apache plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError(‘Error while running apachect1 configtest.\n\nhttpd: Syntax error on line 52 of /etc/httpd/conf/httpd.conf : Syntax error on line 6 of /etc/httpd/conf/extra/httpd-phpmodules.conf : Cannot load /usr/lib/apache/mod_mpm_prefork.so into server: /usr/lib/apache/mod_mpm_prefork.so: indefined symbol: ap_set_listencbratio\n’,)
