Webroot challenge failing all of a sudden (IP issue) // Solution: A and AAAA need to point to the same server!
For a about one and a half years the webroot challenge was working for me fine. Now it is broken and I have no clue to get it working. I spent many hours again with several things browsed via the internet.
My setup for https://www.mediawikiwidgets.org/
<VirtualHost *:80>
ServerAdmin mail@example.info
ServerName www.mediawikiwidgets.org
ServerAlias mediawikiwidgets.org
RedirectPermanent / https://www.mediawikiwidgets.org/
LogLevel warn
CustomLog "|/usr/bin/rotatelogs -l ${APACHE_LOG_DIR}/%Y%m%d.access.log 86400" combined
</VirtualHost>
and
<VirtualHost *:443>
ServerAdmin karsten@hoffmeyer.info
DocumentRoot /path/to/root/
<IfModule mod_rewrite.c>
	RewriteEngine on
	RewriteCond %{DOCUMENT_ROOT}%{REQUEST_URI} !-f
	RewriteCond %{DOCUMENT_ROOT}%{REQUEST_URI} !-d
	RewriteRule ^(.*)$ %{DOCUMENT_ROOT}/w/index.php [L]
</IfModule>
LogLevel warn
</VirtualHost>
This has worked fine. Now I was forced to require login - not authentication.
With authentication I would do for http:
<VirtualHost *:80>
<Directory /path/to/root>
		RewriteEngine on
		RewriteBase /
		RewriteCond %{REQUEST_URI} !^.well-known/acme-challenge
		RewriteRule ^(.*) https://www.mediawikiwidgets.org/$1 [R=301,L]
	</IfModule>
</Directory>
LogLevel warn
</VirtualHost>
This works fine for authentification but it does not for registration:
With e.g. certbot certonly --webroot -w /path/to/root -d www.mediawikiwidgets.org --dry-run I get:
http-01 challenge for www.mediawikiwidgets.org
Using the webroot path /path/to/root for all unmatched domains.
Failed authorization procedure. www.mediawikiwidgets.org (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.mediawikiwidgets.org/.well-known/acme-challenge/PxS4t_GEM9Oj4fElEDL0dwa9NHUa1srhiwDj-PqOZ5w: "<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
  "http://www.w3.org/TR/xhtml1/D"
   Domain: www.mediawikiwidgets.org
   Type:   unauthorized
   Detail: Invalid response from
Apparently I have no idea how to mitigate. Perhaps there are some people around who may help me with my misery. Moreover I am utterly sorry to bother you with something like this but I personally am out of luck. Sadly the DNS challenge is no option for me. :frowning:
I’m getting a 404 file not found error when I try to reach your challenge file. Which isn’t surprisingly, as certbot already removed it after cleaning up :stuck_out_tongue:
Could you put a test file in /path/to/root/.well-known/acme-challenge/ ?
Also, your HTTP to HTTPS is completely broken when I removed the whole acme-challenge and well-known part of the URL. I’m guessing it’s because when you’re not having a DocumentRoot in your HTTP VirtualHost, but you are specifying a specific <Directory> directive, the whole Rewrite part isn’t called upon.
I added a file: Login required - MediaWiki Widgets
I’m guessing it’s because when you’re not having a DocumentRoot in your HTTP VirtualHost, but you are specifying a specific directive, the whole Rewrite part isn’t called upon.
No I showed the whole config file. Perhaps this is the issue. I am wondering why this is working for other domains like this.
Now I'm getting a redirect to HTTPS, which wasn't there before. Did you change anything?
No but I would like to add a document root to 80
Well, a few minutes ago, when I surfed to the HTTP site http://www.mediawikiwidgets.org/, I got a "Everything works" kind of example page of your webserver in German, not the redirect to HTTPS Ăłr your main site through HTTP. And now I'm getting the redirect. So you did change something :wink:
No and you can trust me on this one. However when testing different solutions it got this too in arbitrary occasions. What makes me crazy is that the page you are referring to is at /var/www/html/ whereas default.conf and default-ssl.conf specifiy /var/www/htdocs/. This is indeed driving me crazy too.
The error certbot provides suggests that it is getting /var/www/html/index.html. I do not know why since Apache is configured to go for /var/www/htdocs/…
I just killed this directory since it is unused.
No idea what is going on. The setup worked for one and a half years and it is still working for the other websites on the same server. I am clueless - no kidding.
Or, let*s ask the other way around: What is the expected output of the challenge? Currently I am getting a wiki page as in https://www.mediawikiwidgets.org/.well-known/acme-challenge/ma49FKu-0WHYgor876loNogOXQI6UtASncNqUQcIISo: Should a file or so be served? So if a file should be served I need something that prevents the redirect to the wiki page.
Yes, certbot places a file with a token in it on exactly the location which is requested in the logs.
Ok. So what to do? If I place a file it works like https://www.mediawikiwidgets.org/.well-known/acme-challenge/challenge.txt Moreover I wonder why it worked for one and a half years and now starts failing. The only difference is that I require user to log in. In the meantime I believe that this does not make a difference.
Try renewing again now that the test file works :slight_smile:
Also, in a certbot above you only specified -d www.mediawikiwidgets.org, NOT also -d mediawikiwidgets.org, which is required if you also want the base domain to be accessible through HTTPS.
Sadly it does not. This is driving me crazy. I spent many hours on this and now I am also wasting your time. :frowning:
Try the --manual plugin for testing purposes. The webroot plugin removes the challenge file again, which makes debugging sometimes a little bit more difficult.
Also, what was the log from certbot this time?
I know. I just added www for demonstration purposes. Currently I do not get further to the actual cert.
It works via IPv4 but not IPv6. Make sure your AAAA record is pointing to the correct IPv6 address.
That's very strange, my curl does confirm this, but my Google Chrome gets the file without a hitch..? Going debugging my own workstation now :stuck_out_tongue:
HTTP returns a 404, but HTTPS doesn’t connect so maybe Chrome is failing back to IPv4? It won’t try HTTP because HSTS.
