Hello, I have the same problem like you, I have a website somaapp.com and when I uses VPN, it sends me wrong credentials also, sometimes in some devices, it shows No SSL certificate, if anyone have solution, please write!
Thanks
it you read the old thread it was posted to, his problem was he run ddns client on same machinine with vpn, so DNS pointed to VPN's endpoint, which won't route incoming traffic to you.
Hi Adam, my fix was to move the ddns client (software that reports ip address changes) from my main computer that I use vpn software on to another computer. My ddns client now runs on my webserver. I can now run vpn software without problem.
