SSL Mismatch for DDNS
#1
My DDNS is supported through dyndnss.net. The IP address that I have for deare.dyndnss.net is 73.199.208.160. I have my SSL cert for that DNS through Lets Encrypt. The issue that I have is that when I look at SSL checker, I get the following message “deare.dyndnss.net resolves to 95.216.17.186”. Looking further into this situation I have found that “The security certificate presented by this website was issued for a different website’s address.” Can this be fixed as soon as possible so that I can access my server through my DDNS with security.
#2
Hi @ddeare
checking your nameserver entries this is wrong:
deare.dyndnss.net A 95.216.17.186 yes 1 0
AAAA yes
www.deare.dyndnss.net A 95.216.17.186 yes 1 0
AAAA yes
Your name servers:
You have to change your dns settings, so that the 73.* - ip address is the address of your domain.
The 95.* ip has a certificate
CN=traffic-exchanger.com
	20.11.2018
	18.02.2019
	traffic-exchanger.com, www.traffic-exchanger.com - 2 entries
Looks like a domain forwarding or something else. You must set the A record to 73.*
#3
This is NOT in sync with their system.
Are you using their IP sync tool?: https://dyndnss.net/eng/updater-tool.php
#4
My account updates manually through the web interface. Using that interface, I have updated the account several times. I have an open support request to resolve.
#5
#6
Where is this
http://deare.dyndnss.net  A 95.216.17.186
combination defined? The nameserver is ns3.nsentry.de.
There you have to change something.
#7
If you look at the HTML on http://deare.dyndnss.net/, it’s a dyndnss.net forwarding service. It includes http://73.199.208.160 within an iframe.
So the IP address is correct, but the setup is wrong. It’s an HTTP forwarding service instead of just an A record.
#8
This has got to be the worst DDNS service (option) ever created.
DynDNS Updater Url
Emphasis on URL.
It doesn’t set the FQDN to your IP (like most other DDNS services).
It sets the FQDN to a page that links to a URL (that wraps your IP URL in a frame).
#9
Site URL produces a page like:
[abbreviated for clarity]
<!DOCTYPE html PUBLIC ...>
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="de" lang="de">
<head profile="http://gmpg.org/xfn/11">
<title>deare - Dyndns Free Updater Service by DynDNSs.net</title>
</head>
<frameset rows="100%,*">
<frame frameborder="0" src="http://73.199.208.160">
<noframes>
Diese Webseite verwendet Frames, welche von Ihrem Browser nicht unterst&uuml;tzt werden.
</noframes>
</frameset>
<body>
<p><a href="https://dyndnss.net">DynDNS</a> Powered by dyndnss.net</p>
<p><a href="http://73.199.208.160">deare</a></p>
</body>
</html>
The site uses the term “DynDNS” which seems to conflict with Oracles use of that same term:
From: https://dyn.com/legal/dyn-services-agreement/
The Free Services include the DynDNS® dynamic DNS service and all other services that Oracle makes available to You free of charge on Oracle’s Websites.
#10
